Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
not monitored interface on firewall
output to view failover status gives "not monitored" states on the available interface although all of the interfaces are up & passing traffic. same is the case with other unit.
Please advise how to deal with this.
Thanks!
1 ACCEPTED SOLUTION
Re: not monitored interface on firewall
Sunny,
in your primary asa issue:
monitor-interface Zone1
monitor-interface Zone2
- wait few seconds , then issue "show failover" monitor status on the interfaces should be normal
Can you post the actual output of show failover from primary-active fw.
if your firewall logical interfaces have the (no monitored) output by defaul logical interfaces are not monitored thus you will need to issue from the active firewall monitor-interface nameif .
asa(config)#monitor-interface
Sh failov with values changed:
Interface Zone1 (10.11.2.3): Normal (Not-Monitored)
Zone2 (10.12.3.4): Normal (Not-Monitored)
There is no problem in passing traffic across these firewalls.
failover
failover lan unit primary
failover preempt 120
failover lan interface Failover Vlan155
failover link Stateful_Link Vlan154
failover interface ip Failover 10.2.155.251 255.255.255.252 standby 10.2.155.250
failover interface ip Stateful_Link 10.2.155.249 255.255.255.252 standby 10.2.155.248
In order to enable health monitoring on a specific interface, use the monitor-interface command in global configuration mode: monitor-interface
Even if you are not monitoring an interface, the interface will still pass data traffic!
Sunny,
660
