Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
One way voice problem in Phone proxy
I have configured my ASA for Phone Proxy.The phones gets registered via Phone Proxy but the voice traffic is one direction .Attaching the running config for the same. Kindly help
1 REPLY
Community Member
Re: One way voice problem in Phone proxy
You could be having a routing issue. The voice packet could be going out on a different path and not going back to the ASA's MTA path.
there's 2 method to fix this:
1. add a static route at your router/switch. see this link for more details:http://supportwiki.cisco.com/wiki/index.php/ASA_Phone_Proxy_Troubleshooting_and_Common_Problems
2. or you upgrade your ASA to Version 8.2(1). This version fixed the MTA routing issue. But you need some minor changes on the config such as putting the MTA per interface. for me this is the best way but it's your decision and your own risk...
hth
277
