Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Open same port for multiple servers.
I am sorry if this sounds rudimentary, but I wanted to make sure. I want to open up port 80 to more than one web server. I already have port 80 open on one public IP address and have another one ready to use for another server. My assumption is that I should just be able to create a policy using the additional IP address and use port 80 without any issues. Is that correct to assume? I would also like to know, how one would do this is they only had one public IP address. I believe these should be relatively easy questions for the experts here. Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
If you have a netblock from
If you have a netblock from which you can assign multiple IP addresses then, yes - just asign additional access-list entries and static NAT entries.
If you only had a single (or limited number all in use) public IP address then you would have to use some sort of PAT (port address translation). for instance:
server 0 is <outside address>:80
server 1 is <outside address>:81
server 2 is <outside address>:82
..etc. Your remote users would then have to specify the non-default port (80/81/82) when browsing to the site.
1 REPLY
125
