Oracle database connectivity problem
I am facing some problem with Oracle database connectivity with my application server. While both the servers are put into same DMZ of PIX everything is working fine. But when we put in different DMZs connectivity with DB getting hanged. Then we need to restart the Application server to restore the connectivity. I have permitted ip connectivity between both the server in the pix.
Pls help.
Re: Oracle database connectivity problem
Which IOS version are you using?
Try disabling the SQL inspection.
pix(config)#policy-map global_policy
pix(config-pmap)#class inspection_default
pix(config-pmap-c)#no inspect sqlnet
Thanks for reply.
The OS version is 7.1. I am using Oracle Database not SQL.
Souvik
But Oracle is using SQL , which is over TCP 1521.
ok. let me try it. But one more thing I have permitted ip between the servers. Still do i need inspection?
Souvik
180
