Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ospf retransmission packet over transparent fwsm
Hello everyone!
I have a problem, ospf packets are lost over fwsm in transparent mode. my scheme cisco 6513 (vlan 602) - FWSM (transparent mode)- juniper mx 480 (vlan 1602)
sh ip ospf neighbor 10.25.78.102
 Neighbor 10.25.78.102, interface address 10.25.4.49
    In the area 0.0.0.25 via interface Vlan602
    Neighbor priority is 0, State is FULL, 6 state changes
    DR is 0.0.0.0 BDR is 0.0.0.0
    Options is 0x12 in Hello (E-bit L-bit )
    Options is 0x52 in DBD (E-bit L-bit O-bit)
    LLS Options is 0x1 (LR)
    Dead timer due in 00:00:38
    Neighbor is up for 00:34:26
    Index 13/13, retransmission queue length 1377, number of retransmission 1829
    First 0x56B71B24(22845)/0x541589D4(1980410) Next 0x56B71B24(22845)/0x53145CDC(1982479)
    Last retransmission scan length is 1, maximum is 3
    Last retransmission scan time is 0 msec, maximum is 0 msec
    Link State retransmission due in 170 msec
fwsm version 4.1(15)
On fwsm there is a separate transparent context
interface Vlan1602
 nameif outside_vos2
 bridge-group 5
 security-level 100
 interface Vlan602
 nameif inside_vos2
 bridge-group 5
 security-level 100
 mtu outside_vos2 1600
 mtu inside_vos2 1600
 same-security-traffic permit inter-interface
 access-group outside_vos2 in interface outside_vos2
 access-group inside_vos2 in interface inside_vos2
 vld-fwsm-3/Acon# sh access-list inside_vos2
access-list inside_vos2; 7 elements
access-list inside_vos2 line 1 extended permit icmp any any (hitcnt=3013) 0xdc0494dc
access-list inside_vos2 line 2 extended permit ospf any any (hitcnt=11870) 0x1a46fe16
access-list inside_vos2 line 3 extended permit ip any any (hitcnt=1) 0x8be5ad9f
access-list inside_vos2 line 4 extended permit ospf host 224.0.0.5 any (hitcnt=0) 0x96c6702
access-list inside_vos2 line 5 extended permit ospf host 224.0.0.6 any (hitcnt=0) 0xc8bc65d9
access-list inside_vos2 line 6 extended permit ospf any host 224.0.0.6 (hitcnt=0) 0xa6831776
access-list inside_vos2 line 7 extended permit ospf any host 224.0.0.5 (hitcnt=0) 0x1c1248b
vld-fwsm-3/Acon# sh access-list outside_vos2
access-list outside_vos2; 7 elements
access-list outside_vos2 line 1 extended permit icmp any any (hitcnt=3010) 0xda598b52
access-list outside_vos2 line 2 extended permit ospf any any (hitcnt=7886) 0x112dad2b
access-list outside_vos2 line 3 extended permit ip any any (hitcnt=10) 0x910c4a5a
access-list outside_vos2 line 4 extended permit ospf host 224.0.0.5 any (hitcnt=0) 0x2d6480d7
access-list outside_vos2 line 5 extended permit ospf host 224.0.0.6 any (hitcnt=0) 0x4a8401c0
access-list outside_vos2 line 6 extended permit ospf any host 224.0.0.5 (hitcnt=0) 0x70f8cbba
access-list outside_vos2 line 7 extended permit ospf any host 224.0.0.6 (hitcnt=0) 0x60783961
FWSM logs(there is no drops):
6|Apr 11 2014|14:47:40|302023|||||Teardown IP protocol 89 connection 12379739847668082336 for outside_vos2:10.25.4.49 to inside_vos2:10.25.4.54 duration 0:00:06 bytes 1520
6|Apr 11 2014|14:47:40|302022|||||Built IP protocol 89 connection 12379739847668082338 for inside_vos2:10.25.4.49 (10.25.4.49) to outside_vos2:10.25.4.54 (10.25.4.54)
6|Apr 11 2014|14:47:38|302022|||||Built IP protocol 89 connection 12379739847668082337 for inside_vos2:224.0.0.5 (224.0.0.5) to outside_vos2:10.25.4.54 (10.25.4.54)
6|Apr 11 2014|14:47:36|302023|||||Teardown IP protocol 89 connection 12379739847668082335 for inside_vos2:10.25.4.54 to outside_vos2:10.25.4.49 duration 0:00:05 bytes 164
6|Apr 11 2014|14:47:34|302022|||||Built IP protocol 89 connection 12379739847668082336 for outside_vos2:10.25.4.49 (10.25.4.49) to inside_vos2:10.25.4.54 (10.25.4.54)
6|Apr 11 2014|14:47:31|302023|||||Teardown IP protocol 89 connection 12379739847668082332 for outside_vos2:10.25.4.49 to inside_vos2:10.25.4.54 duration 0:00:05 bytes 1520
6|Apr 11 2014|14:47:31|302022|||||Built IP protocol 89 connection 12379739847668082335 for inside_vos2:10.25.4.49 (10.25.4.49) to outside_vos2:10.25.4.54 (10.25.4.54)
6|Apr 11 2014|14:47:29|302023|||||Teardown IP protocol 89 connection 12379739847668082329 for inside_vos2:10.25.4.54 to outside_vos2:224.0.0.5 duration 0:00:09 bytes 196
6|Apr 11 2014|14:47:26|302023|||||Teardown IP protocol 89 connection 12379739847668082330 for inside_vos2:10.25.4.54 to outside_vos2:10.25.4.49 duration 0:00:05 bytes 164
6|Apr 11 2014|14:47:25|302022|||||Built IP protocol 89 connection 12379739847668082332 for outside_vos2:10.25.4.49 (10.25.4.49) to inside_vos2:10.25.4.54 (10.25.4.54)
6|Apr 11 2014|14:47:21|302023|||||Teardown IP protocol 89 connection 12379739847668082328 for outside_vos2:10.25.4.49 to inside_vos2:10.25.4.54 duration 0:00:05 bytes 1520
6|Apr 11 2014|14:47:21|302022|||||Built IP protocol 89 connection 12379739847668082330 for inside_vos2:10.25.4.49 (10.25.4.49) to outside_vos2:10.25.4.54 (10.25.4.54)
6|Apr 11 2014|14:47:19|302022|||||Built IP protocol 89 connection 12379739847668082329 for inside_vos2:224.0.0.5 (224.0.0.5) to outside_vos2:10.25.4.54 (10.25.4.54)
6|Apr 11 2014|14:47:17|302023|||||Teardown IP protocol 89 connection 12379739847668082327 for inside_vos2:10.25.4.54 to outside_vos2:10.25.4.49 duration 0:00:05 bytes 164
6|Apr 11 2014|14:47:15|302022|||||Built IP protocol 89 connection 12379739847668082328 for outside_vos2:10.25.4.49 (10.25.4.49) to inside_vos2:10.25.4.54 (10.25.4.54)
6|Apr 11 2014|14:47:12|302023|||||Teardown IP protocol 89 connection 12379739847668082324 for outside_vos2:10.25.4.49 to inside_vos2:10.25.4.54 duration 0:00:04 bytes 1520
6|Apr 11 2014|14:47:11|302022|||||Built IP protocol 89 connection 12379739847668082327 for inside_vos2:10.25.4.49 (10.25.4.49) to outside_vos2:10.25.4.54 (10.25.4.54)
6|Apr 11 2014|14:47:10|302023|||||Teardown IP protocol 89 connection 12379739847668082322 for inside_vos2:10.25.4.54 to outside_vos2:224.0.0.5 duration 0:00:10 bytes 196
6|Apr 11 2014|14:47:07|302022|||||Built IP protocol 89 connection 12379739847668082324 for outside_vos2:10.25.4.49 (10.25.4.49) to inside_vos2:10.25.4.54 (10.25.4.54)
6|Apr 11 2014|14:47:07|302023|||||Teardown IP protocol 89 connection 12379739847668082323 for inside_vos2:10.25.4.54 to outside_vos2:10.25.4.49 duration 0:00:05 bytes 164
on svi interface cisco 6500 and juniper mx480 - ip mtu 1400.
when traffic goes without FWSM no packet loss
    In the area 0.0.0.25 via interface Vlan1602
    Neighbor is up for 00:00:36
    Index 13/13, retransmission queue length 0, number of retransmission 0
    First 0x0(0)/0x0(0) Next 0x0(0)/0x0(0)
    Last retransmission scan length is 0, maximum is 0
Everyone's tags (2)
165
