Outbound WAN Load balancing Does not work on ASA 5510
Hi There
I have a Cisco ASA 5510 with two WAN connections. WAN Interface #1 is configured statically with a static route, and this interface also handles all inbound traffic. WAN Interface #2 is a Cable Internet service, which I want to route all Outbound traffic through (since i dont get charged for bandwidth on this line) but I also want certain traffic, such as SMTP and RDP traffic to always go through Wan Interface #1.
I used to be able to do this easily on my SonicWALL PRO 2040. I was hoping the CISCO ASA 5510 would be able to do this as well but it seems that all I can accomplish is an Active/Passive style WAN Failover, whereby if the first WAN Interface stops responding to Pings (Based on setting up a Track) then the 2nd WAN Interface will start forwarding outbound traffic.
Is there a way to make both WAN Interfaces handle traffic? This is ONLY for Outbound traffic and not Inbound traffic.
Thanks.
Re: Outbound WAN Load balancing Does not work on ASA 5510
with cisco u can achieve what you want easly with a feature called PBR however this feature not availabe with cisco ASA
what can suggest you is have a look at the following link it might be helpful for you as it is address an issue similer to urs but not the same
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
note: with ASA active/active methodology you can achieve loadshareing but not load balancing regarding that with active/active u will not be able to use VPN because the Firewall will be operating in miltuple context mode !!
good luck
please, if helpful Rate
As a temporary or band-aid type of solution you could put specific routes pointing out towards WAN interace # 1 for the RDP destinations. That is if you know before hand which sites you will be remotely connecting to. Otherwise this won't be possible with the ASA.
Farrukh
586
