outgoing FTP traffic is very low
claude.berthet
HI,
I use VPN between ASA 5520 and 3640 when i try to transfert file from the ASA to 3640 side the transfer is very low. When i tranfer file from 3640 to ASA side it's seem to be good.
On the ASA the configuration was made with ASDM.
Do you have an idea ?
ROBERTO TACCON
Level 4
Level 4
- the link between the asa and the router are simmetric (the mtu are the same) ?
- are there any qos rule on the asa (and on the 3640) ?
- do you use the same ftp file / programs / method (active or passive) / ... in both directions ?
abinjola
please send ne the output of 1) sh run policy 2)sh asp drop
claude.berthet
Thank's for your help.
It's ok for me.
You are right the cause was a default class map with a limited bandwith on the remote router.
Thank's
