Outside to Inside with NAT
Hyi have face problem regradin traffic from outside to insdie having applying acl below here
access-list 101 permit ip any any
APPLY on outside interface
access-group 101 in interface outside
but my traffice didnt pass through from outside to indie
Navaz
Navaz
1 ACCEPTED SOLUTION
Re: Outside to Inside with NAT
I think that you can use.
VIP Purple
can you exactly describe what you want to allow on your ASA? Which is the ASA-version you are running and can the ASA reach the internet and the internal server that you want to expose to the internet? The actual config can also help.
And "permit ip any any" is most likely not what you want to use on a firewall.
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
Version 8.0(2) and ASA ping both sides (outside to internet and inside to internal network).
Here is the show running configuration
ASA(config)# sh running-config
: Saved
ASA Version 8.0(2)
hostname ASA
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 10.1.1.1 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/4
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/5
shutdown
no nameif
no security-level
no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
access-list 101 extended permit ip any any
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 10.1.1.30
nat (inside) 1 192.168.1.0 255.255.255.0
access-group 101 in interface inside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
prompt hostname context
Cryptochecksum:a910fcee5200493f2ed21db7bd2f82d6
: end
ASA(config)#
Navaz
Message was edited by: Navaz Wattoo
Navaz
VIP Purple
So it's not a real network but learning how to operate the ASA?
You should start with NAT and think about if you really need NAT. In your diagram inside and outside should have full routing reachability, so NAT is not needed.
On the Config-Guide you find all info how NAT works on the ASA:
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/cfgnat.html
start with the commands "nat", "global" and "nat-control". For your case, all of these can be removed from the config and reachability should be there.
If you want to simulate a situation where the outside interface connects to the internet you need to configure a ststic translation and you should keep the "nat" and "global". The additional config you need is a "static" command.
After that go over to the configuration of access-control:
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/nwaccess.html
You don't want to allow any traffic into your network.
Check routing , i dont see any.
- Pankaj
VIP Purple
the systems in this scenario are directly connected so there is no need for an extra routing-config. Of course you are right if this would be an internet-connected setup. There at least a default-route would be needed.
Silver
Have a look here:
http://www.darkmoon.org.uk/173
Regards Simon
http://www.linksysinfo.org
Regards Simon http://www.linksysinfo.org
Hello Navaz,
Along with routing and the ACL, you will also need to have a static xlate configured to allow the inbound traffic. I don't see that in your configuration.
can you please send me the xlate configuration?
Navaz
Navaz
It should look like this:
Static (inside,outside) 192.168.1.0 192.168.1.0 net mask 255.255.255.0
I'm not sure what your topology is, but you will have to be able to route to the 192.168.1.0 network from your outside host(s).
Sorry, no space in the netmask keyword. The iPad auto correct strikes again... :-)
David i am sending you topology and the configuration that i configured.
: Saved
ASA Version 8.0(2)
hostname ASA
names
nameif outside
security-level 0
nameif inside
security-level 100
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
arp timeout 14400
nat-control
static (outside,inside) 10.1.1.30 10.1.1.2 netmask 255.255.255.255
telnet timeout 5
ssh timeout 5
console timeout 0
: end
ASA(config)#
Navaz
Navaz
anyone have solution of this?
Navaz
Navaz
Silver
what traffic (ports) are you try to let in from outside in and to where?
Regards Simon
i need any kind of traffice pass through both side that from inside to outside and outside to inside
Thanks and Regards
Navaz
Navaz
Hello Navaz,
I think we are confused here.
We all asume this is just for testing purposes.
If what you want is to allow all traffic traversing the ASA from out in, in out
No nat-control
no global (outside) 1 10.1.1.30
no nat (inside) 1 192.168.1.0 255.255.255.0
no static (outside,inside) 10.1.1.30 10.1.1.2 netmask 255.255.255.255
Leave the ACL configuration u have so far and then you will have a Firewall configured to act as No Firewall hehe weird enough!
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Check the routes on your routers, even it is directly connected but you need a route on each router for the other subnet behind the firewall.
OR
You can configure static xlate on the firewall to reach the internal subnet usind a direct natted IP from the external range
Thanks, Anas *--* Please rate the useful post,its free ;) *--*
i am sending you my NAT configuration
nat-control
global (outside) 1 10.1.1.10
static (inside,outside) 10.1.1.2 192.168.1.2 netmask 255.255.255.255
access-group 101 out interface inside
And Routes at Inside Router
S       10.1.1.2 [1/0] via 192.168.1.1
C    192.168.1.0/24 is directly connected, GigabitEthernet0/0
And Routes at Outside Router
C       10.1.1.0 is directly connected, GigabitEthernet0/0
     192.168.1.0/32 is subnetted, 1 subnets
S       192.168.1.2 [1/0] via 10.1.1.1
Problem is:
               The problem is that i cant ping from outside to inside.
Navaz
Navaz
Option 1:
     No nat-control
     using ACL for permit and static route for routing
Option 2
nat con-trol
using nat0 (exempt).
can i use static nat for low to high and nat globle for hihg to low?
Navaz
Navaz
can you send me the configuration?
Navaz
Navaz
734
