Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
PABX VOIP with ASA issue.
Hi all after the client put all their servers network behind the fireweall ASA  5585 the voip call´s was not getting thru and not working , at the time of the maintenance window i was not abble to get any log of the issue because i as running out of time so i made a rollback on the change, there was no access-list at that time i did permit ip any any at both directions at the time of the issue and still not working.
I have seen that some VOIP systems uses some ip options on the calls and the ip option is enable by default on the 8.2 version ( i am using ver 8.2(5)).
it´s possible to turn off the inpection of the ip options and  this could fix the issue ?
PABX brand is siemens.
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
Thank you.
1 REPLY
I dont think IP options will do the trick. What voice protocol were you using? SIP, Skinny? H323?  If you would have removed the inspection for the voice protocol and then permit IP traffic on the interfaces involved that would have show an issue with the inspections on the ASA.
Let me know.
Mike
Mike
284
