Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
packet-trace bug in asdm 7.3(1) running 9.3(1) on an ASA5555-X
I've discovered a bug in the newly added SGT option when running a packet trace using ASDM. When you do not want to add or use the SGT number (leaving it unchecked), the command sent to the ASA5555 includes invalid syntax:
packet-tracer input outside tcp inline-tag -1 80 25567 xml
The "inline-tag -1" should not be included when the SGT number option is not selected and since it is, with an invalid number, the packet-trace fails every time. Command line works fine without the extra parameter and invalid value.
Question is -- has anyone else replicated this problem, or is it just new with this release?
Everyone's tags (1)
Community Member
Same problem: ASA 5510
Same problem: ASA 5510 running ASA 8.2(3) and ASDM 7.3(1).
Community Member
packet tracer also fails for
packet tracer also fails for me.
running ASA 5520 8.4(5) and ASDM 7.3(1).
I downgraded back to 7.2(2) so I would have packet tracer capabilities.
Community Member
I have updated the ASDM to
I have updated the ASDM to version 7.3(1)101 and the problem I was having with packet tracer has been fixed.
Community Member
Same problem. ASA 5505
Same problem. ASA 5505 running ASA 8.4(2) and ASDM 7.3(1)
Community Member
Packet tracer bug fixed in
Packet tracer bug fixed in ASDM 7.3(1.101). Verified. Works.
