Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Packet Tracer (Implicit Deny) issue
I am trying to do a simple packet tracer  on my ASA and this is what I am getting
ASA#       packet-tracer input DMZ tcp 10.250.0.5 2234 10.250.0.6 22 xml
<Phase>
<id>1</id>
<type>ROUTE-LOOKUP</type>
<subtype>input</subtype>
<result>ALLOW</result>
<config>
</config>
<extra>
in   10.250.0.4      255.255.255.252 DMZ
</extra>
</Phase>
<Phase>
<id>2</id>
<type>ACCESS-LIST</type>
<subtype></subtype>
<result>DROP</result>
<config>
Implicit Rule
</config>
<extra>
</extra>
</Phase>
<result>
<input-interface>DMZ</input-interface>
<input-status>up</input-status>
<input-line-status>up</input-line-status>
<output-interface>DMZ</output-interface>
<output-status>up</output-status>
<output-line-status>up</output-line-status>
<action>drop</action>
<drop-reason>(acl-drop) Flow is denied by configured rule</drop-reason>
</result>
ASA#
The 10.250.0.6 deve is a router directly connected to the DMZ interface 10.250.0.5
However I am getting the reason for droped packet as (Implicit Rule) which I can see is only on the global interface.
I am permiting ip any any on that same interface as well.
How can I make this work?
The reson for this is I need my ASA to authenticate with TACACS server which is behind the 10.250.0.6 router
1 ACCEPTED SOLUTION
Re: Packet Tracer (Implicit Deny) issue
It's just strange that TACACS can't be ping'd, yet traffic through the ASA is good.
What type of device is 10.250.0.6? Do you have access to it?
Community Member
Hi Kemal,
Reading your post 2 things came in to my mind:
1. Why you use /30 mask on your firewall? With this mask you have only 2 useable addresses. One you're going to use for the firewall interface IP, second one for the router.
2. Packet tracer with specified same source and destination network will always fail even if you allow all the traffic and enable same security traffic. Devices communicating within the same subnet will not hit the firewall.
Unless this is just a typo and you should just change the destination IP in the packet tracer? What is your TACACS IP ?
Mariusz
Community Member
the reason I have a /30 between my ASA and my router is tat behind my router I have another IP scope for my LAN (10.250.100.128/25)
I am douing dynamic pat on the asa and the router for the workstations to get out
the ip address of the tacacs server is 10.250.100.142 I am getting the same packet tracer resoult with the other IP as well
Community Member
Would you be able to post the config fot us?
Community Member
Hello
yes the config is below...
The tow router behing DMZ and INSIDE interfaces on the ASA are able to authenticate against the tacaacs server
ASA Version 9.1(2)
hostname ASA1
enable password Ev0iTru97MKu8IiT encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
names
interface GigabitEthernet0/0
nameif inside
security-level 100
ip address 10.250.0.1 255.255.255.252
authentication key eigrp 99 ********* key-id 99
authentication mode eigrp 99 md5
interface GigabitEthernet0/1
nameif DMZ
security-level 75
ip address 10.250.0.5 255.255.255.252
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/0
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/1
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/3
nameif outside
security-level 0
ip address dhcp setroute
ftp mode passive
object-group service DM_INLINE_TCP_2 tcp
port-object eq ssh
port-object eq telnet
access-list inside_access_in extended permit ip any4 any4
access-list DMZ_access_in extended permit tcp any4 any4 object-group DM_INLINE_TCP_2
access-list DMZ_access_in extended permit ip any4 any4
access-list global_access extended permit ip any4 any4
pager lines 24
logging enable
logging buffered informational
mtu inside 1500
mtu DMZ 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (DMZ,outside) source dynamic any interface
nat (inside,outside) source dynamic any interface
access-group inside_access_in in interface inside
access-group DMZ_access_in in interface DMZ
access-group global_access global
router eigrp 99
no auto-summary
eigrp router-id 10.250.0.5
network 10.250.0.0 255.255.255.252
network 10.250.0.4 255.255.255.252
passive-interface default
no passive-interface inside
no passive-interface DMZ
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server BiHTac protocol tacacs+
accounting-mode simultaneous
aaa-server BiHTac (DMZ) host 10.250.100.142  >>>>>>>>>>>>>>>> Tacacs Server
key ********
user-identity default-domain LOCAL
aaa authentication http console BiHTac LOCAL
aaa authentication ssh console BiHTac LOCAL
aaa authentication enable console BiHTac LOCAL
aaa authentication serial console BiHTac LOCAL
aaa authentication telnet console BiHTac LOCAL
aaa authorization command BiHTac LOCAL
http server enable
http 10.250.100.140 255.255.255.255 DMZ   >>>>>>>>>>>>>>>>>>>>> This is my Domain Controler
http 10.250.0.6 255.255.255.255 DMZ
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh 10.250.100.140 255.255.255.255 DMZ  >>>>>>>>>>>>>>>>>>>>> This is my Domain Controler
ssh 10.250.0.6 255.255.255.255 DMZ
ssh timeout 20
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username blah password SDFGHJOLKJFCVHJGK. encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http
https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email
callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:1e3912f897a34d901d4e60d69e1a3e05
: end
ASA Version 9.1(2)
hostname ASA1
names
nameif inside
security-level 100
nameif DMZ
security-level 75
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
nameif outside
security-level 0
ftp mode passive
port-object eq ssh
pager lines 24
logging enable
mtu inside 1500
mtu DMZ 1500
mtu outside 1500
no failover
arp timeout 14400
router eigrp 99
no auto-summary
key ********
http server enable
telnet timeout 5
ssh timeout 20
ssh version 2
console timeout 0
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
callhome@cisco.com
: end
any suggestions?
Community Member
Hi Kemal,
Sorry, but I have few more questions
Can you see the 10.250.100.128/25 network in the routing table (learned by eigrp)?
Are you able to ping the 10.250.100.142 from the ASA's DMZ interface?
Can you please post the result of
packet-tracer input DMZ tcp 10.250.0.5 2234 10.250.100.142 22 ?
Mariusz
Community Member
Hello Mariusz,
I can see the 10.250.100.128/25 network in my routing table via EIGRP
here are the resoults you have asked for
ASA# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 75.132.0.1 to network 0.0.0.0
D    192.168.250.0 255.255.255.248 [90/28416] via 10.250.0.2, 12:02:04, inside
D    10.250.100.128 255.255.255.128 [90/28416] via 10.250.0.6, 12:01:54, DMZ
D    10.250.100.0 255.255.255.128 [90/28416] via 10.250.0.2, 12:02:04, inside
D    10.250.1.1 255.255.255.255 [90/130816] via 10.250.0.6, 12:01:54, DMZ
C    10.250.0.0 255.255.255.252 is directly connected, inside
C    10.250.0.4 255.255.255.252 is directly connected, DMZ
C    75.11.11.0 255.255.192.0 is directly connected, outside
d*   0.0.0.0 0.0.0.0 [1/0] via 75.11.11.1, outside
ASA#
ASA# ping 10.250.100.142
Sending 5, 100-byte ICMP Echos to 10.250.100.142, timeout is 2 seconds:
Success rate is 0 percent (0/5)
ASA# ping DMZ 10.250.100.142
ASA#
ASA#
ASA#  traceroute 10.250.100.142
Tracing the route to 10.250.100.142
1   *  *  *
2   *  *  *
3   *  *
ASA#
ASA# packet-tracer input dmZ tcp 10.250.0.5 2234 10.250.100.142 22
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.250.100.128  255.255.255.128 DMZ
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: DMZ
input-status: up
input-line-status: up
output-interface: DMZ
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
ASA#
When I go to my ASDM and Under MOnitoring/Properties/AAA Servers I see the Tacacs Server configured but under status it says Failed.
here are some of the statistics of that screen
BiHTacTACACS+10.250.100.142Failed
Server port:  49
Number of pending requests  0
Average round trip time   0ms
Number of authentication requests 12
Number of authorization requests 19
Number of accounting requests  0
Number of retransmissions  0
Number of accepts   0
Number of rejects   0
Number of challenges   0
Number of malformed responses  0
Number of bad authenticators  0
Number of timeouts   31
Number of unrecognized responses 0
Also it would be worth mentioning that I can ping 10.250.0.5 (DMZ interface) of the ASA from the Tacacs Server
C:\Users\aaa>ping 10.250.0.5
Pinging 10.250.0.5 with 32 bytes of data:
Reply from 10.250.0.5: bytes=32 time=1ms TTL=254
Ping statistics for 10.250.0.5:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 1ms, Maximum = 1ms, Average = 1ms
C:\Users\aaa>tracert 10.250.0.5
Tracing route to 10.250.0.5 over a maximum of 30 hops
  1     1 ms     1 ms     1 ms  10.250.100.129
  2     1 ms     1 ms     1 ms  10.250.0.5
Trace complete.
We can see that an ACL is dropping the traffic. Can you do another packet-tracer with detail?
packet-tracer input DMZ udp 10.250.0.5 2234 10.250.100.142 49 detail
Community Member
Sure.. It looks like that it gets dropped by the Implicit Deny rule under Global
ASA# packet-tracer input DMZ udp 10.250.0.5 2234 10.250.100.142 49 detail
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Forward Flow based lookup yields rule:
in  id=0x5774bbf0, priority=1, domain=permit, deny=false
        hits=39042567, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0100.0000.0000
        input_ifc=DMZ, output_ifc=any
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0x5775fdc0, priority=500, domain=permit, deny=true
        hits=1, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip/id=10.250.0.5, mask=255.255.255.255, port=0, tag=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0, dscp=0x0
Result:
input-status: up
output-status: up
Action: drop
What are you seeing in the logs on your TACACS server? Do you see authentication attempts fromthe ASA?
Community Member
No I dont see any requests from the 10.250.0.5 (DMZ) to the TACACS Server
here are the only two logs I see on my Tacacs
<94> 2014-01-01 08:11:58 [10.250.100.129:36682] New client connection opened for 10.250.100.15:13334 TID:11
<94> 2014-01-01 08:18:46 [10.250.100.15:13334] New client connection opened for 10.250.100.15:59242 TID:12
The 10.250.100.15 router is behind the 10.250.0.1 (inside interface)
Here is a packet tracer for that interface
ASA# packet-tracer input inside udp 10.250.100.15 2234 10.250.100.142 49 de$
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
in  id=0x5828c890, priority=13, domain=permit, deny=false
        hits=27554, user_data=0x53100dc0, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0
        input_ifc=inside, output_ifc=any
Phase: 3
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
in  id=0x56e6b410, priority=0, domain=nat-per-session, deny=true
        hits=13320, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
        input_ifc=any, output_ifc=any
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0x57717078, priority=0, domain=inspect-ip-options, deny=true
        hits=28028, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 5
Type: NAT
Result: ALLOW
Config:
Reverse Flow based lookup yields rule:
        hits=13322, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0x57751878, priority=0, domain=inspect-ip-options, deny=true
        hits=18130, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 56599, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_tracer_drop
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
input-interface: inside
input-status: up
output-status: up
Action: allow
And here is the traceroute from 10.250.100.15 to 10.250.100.142
WLAN_AP>traceroute 10.250.100.142
  1 10.250.100.1 0 msec 0 msec 0 msec
  2 10.250.0.6 0 msec 0 msec 0 msec
  3 10.250.100.142 8 msec 0 msec 0 msec
I am puzzeld on how the above device can talk to the Tacacs Server but my ASA DMZ interface cant even Ping it.
Can you try this-
Remove-
Add-
aaa-server BiHTac (inside) host 10.250.100.142
key ********
Community Member
Negative
I now cant even log in using my local database
key *****
http server enable
http 10.250.100.140 255.255.255.255 inside
http 10.250.0.2 255.255.255.255 inside
ssh 10.250.100.140 255.255.255.255 inside
ssh 10.250.0.2 255.255.255.255 inside
ssh timeout 20
ssh version 2
When it was set to (DMZ) you were also using local creds to get in correct?
Community Member
correct,
now I cant get in via ssh or http on inside interface
The only access I have is via console
I removed the ssh and http configuration for DMZ
Go ahead and change it back to (DMZ). Can you enable debug for TACACS and post some of the debug?
Community Member
you mean to enable tacacs debug on the ASA?
Yes, sorry.
Community Member
here is what I see
%ASA-4-409023: Attempting AAA Fallback method LOCAL for Authentication request for user kzuko : Auth-server group BiHTac unreachable
%ASA-6-113015: AAA user authentication Rejected : reason = Invalid password : local database : user = kzuko
%ASA-6-611102: User authentication failed: Uname: kzuko
%ASA-6-315011: SSH session from 10.250.0.6 on interface DMZ for user "kzuko" disconnected by SSH server, reason: "Internal error" (0x00)
%ASA-6-302014: Teardown TCP connection 61690 for DMZ:10.250.0.6/54569 to identity:10.250.0.5/22 duration 0:00:07 bytes 1347 TCP FINs
Community Member
Sorry Wrong log
here is the debug
%ASA-6-302013: Built outbound TCP connection 61851 for inside:10.250.100.142/49 (10.250.100.142/49) to identity:10.250.0.1/31091 (10.250.0.1/31091)
%ASA-6-110003: Routing failed to locate next hop for TCP from identity:10.250.0.1/31091 to inside:10.250.100.142/49
mk_pkt - type: 0x2, session_id: 315
mkpkt - authorize user: bihadmin
cmd=no
cmd-arg=logging cmd-arg=console  Tacacs packet sent
%ASA-6-302014: Teardown TCP connection 61851 for inside:10.250.100.142/49 to identity:10.250.0.1/31091 duration 0:00:00 bytes 0 No valid adjacency
Sending TACACS Authorization message. Session id: 315, seq no:1
%ASA-6-302013: Built outbound TCP connection 61852 for inside:10.250.100.142/49 (10.250.100.142/49) to identity:10.250.0.1/52801 (10.250.0.1/52801)
TACACS Request timed out
TACACS Session finished. Session id: 315, seq no: 1
mk_pkt - type: 0x2, session_id: 316
cmd=no
%ASA-6-302014: Teardown TCP connection 61852 for inside:10.250.100.142/49 to identity:10.250.0.1/52801 duration 0:00:00 bytes 0 No valid adjacency
Sending TACACS Authorization message. Session id: 316, seq no:1
%ASA-6-302013: Built outbound TCP connection 61853 for inside:10.250.100.142/49 (10.250.100.142/49) to identity:10.250.0.1/28448 (10.250.0.1/28448)
TACACS Session finished. Session id: 316, seq no: 1
mk_pkt - type: 0x2, session_id: 317
cmd=no
cmd-arg=logging %ASA-6-302014: Teardown TCP connection 61853 for inside:10.250.100.142/49 to identity:10.250.0.1/28448 duration 0:00:00 bytes 0 No valid adjacency
Sending TACACS Authorization message. Session id: 317, seq no:1
%ASA-2-113022: AAA Marking TACACS+ server 10.250.100.142 in aaa-server group BiHTac as FAILED
BIHASA(config)# TACACS Request timed out
TACACS Session finished. Session id: 317, seq no: 1
Big help, thanks.
Can you post another show route?
Community Member
ASA(config)# sh route
D    192.168.250.0 255.255.255.248 [90/28416] via 10.250.0.2, 38:50:54, inside
D    10.250.100.128 255.255.255.128 [90/28416] via 10.250.0.6, 38:50:44, DMZ
D    10.250.100.0 255.255.255.128 [90/28416] via 10.250.0.2, 38:50:54, inside
D    10.250.1.1 255.255.255.255 [90/130816] via 10.250.0.6, 38:50:44, DMZ
C    75.132.0.0 255.255.192.0 is directly connected, outside
d*   0.0.0.0 0.0.0.0 [1/0] via 75.132.0.1, outside
The routing looks good. In your TACACS server, what IP is configured as the host? The ASA's DMZ address?
Can we try and put a host specific route in for the TACACS server?
route DMZ 10.250.100.142 255.255.255.255 10.250.0.6
Then check the debug log again.
Community Member
Ok did that but still nothing
I am also not seeng much in the debug
sh debug  tacacs
%ASA-4-409023: Attempting AAA Fallback method LOCAL for Authorization request for user bihadmin : Auth-server group BiHTac unreachable
debug tacacs session
ASA(config)# %ASA-7-111009: User 'bihadmin' executed cmd: show debug tacacs
I got debug tacacs and debug tacacs session running on logging console debugging
Community Member
ok I have noticed that these error loggs come in very late. I got this error log below 5 min later
%ASA-7-609001: Built local-host inside:10.250.100.142
%ASA-6-302013: Built outbound TCP connection 63066 for inside:10.250.100.142/49 (10.250.100.142/49) to identity:10.250.0.1/6622 (10.250.0.1/6622)
%ASA-6-110003: Routing failed to locate next hop for TCP from identity:10.250.0.1/6622 to inside:10.250.100.142/49
mk_pkt - type: 0x2, session_id: 332
cmd=show
cmd-arg=debug cmd-arg=tacacs  Tacacs packet sent
%ASA-6-302014: Teardown TCP connection 63066 for inside:10.250.100.142/49 to identity:10.250.0.1/6622 duration 0:00:00 bytes 0 No valid adjacency
%ASA-7-609002: Teardown local-host inside:10.250.100.142 duration 0:00:00
Sending TACACS Authorization message. Session id: 332, seq no:1
%ASA-6-302013: Built outbound TCP connection 63067 for inside:10.250.100.142/49 (10.250.100.142/49) to identity:10.250.0.1/46116 (10.250.0.1/46116)
TACACS Session finished. Session id: 332, seq no: 1
mk_pkt - type: 0x2, session_id: 333
cmd=show
cmd-arg=debug %ASA-6-302014: Teardown TCP connection 63067 for inside:10.250.100.142/49 to identity:10.250.0.1/46116 duration 0:00:00 bytes 0 No valid adjacency
Sending TACACS Authorization message. Session id: 333, seq no:1
%ASA-6-302013: Built outbound TCP connection 63068 for inside:10.250.100.142/49 (10.250.100.142/49) to identity:10.250.0.1/47263 (10.250.0.1/47263)
TACACS Session finished. Session id: 333, seq no: 1
mk_pkt - type: 0x2, session_id: 334
cmd=show
cmd-arg=debug %ASA-6-302014: Teardown TCP connection 63068 for inside:10.250.100.142/49 to identity:10.250.0.1/47263 duration 0:00:00 bytes 0 No valid adjacency
Sending TACACS Authorization message. Session id: 334, seq no:1
BIHASA(config)# TACACS Session finished. Session id: 334, seq no: 1
%ASA-6-305012: Teardown dynamic UDP translation from inside:10.250.100.4/52561 to outside:75.1.1.1/52561 duration 0:00:31
Community Member
I have also noticred this
It mentions "inside" the 10.250.100.142 is behind the DMZ
ok... for some reason it didint take my last commands when I was putting it back on to the DMZ
Lets try the debug again
Community Member
Nothing no debug loggs this time when I try to connect
Community Member
sometimes I see this
mk_pkt - type: 0x2, session_id: 370
cmd=show
cmd-arg=access-list cmd-arg=DMZ_access_in cmd-arg=brief  Tacacs packet sent
Sending TACACS Authorization message. Session id: 370, seq no:1
TACACS Request Timed out. Session id: 370, seq no:1
mk_pkt - type: 0x2, session_id: 371
cmd=show
Sending TACACS Authorization message. Session id: 371, seq no:1
TACACS Session finished. Session id: 370, seq no: 1
TACACS Request Timed out. Session id: 371, seq no:1
mk_pkt - type: 0x2, session_id: 372
cmd=show
Sending TACACS Authorization message. Session id: 372, seq no:1
TACACS Session finished. Session id: 371, seq no: 1
TACACS Request Timed out. Session id: 372, seq no:1
TACACS Session finished. Session id: 372, seq no: 1
mk_pkt - type: 0x2, session_id: 373
cmd=show
Sending TACACS Authorization message. Session id: 373, seq no:1
TACACS Request Timed out. Session id: 373, seq no:1
mk_pkt - type: 0x2, session_id: 374
cmd=show
Sending TACACS Authorization message. Session id: 374, seq no:1
TACACS Session finished. Session id: 373, seq no: 1
TACACS Request Timed out. Session id: 374, seq no:1
mk_pkt - type: 0x2, session_id: 375
cmd=show
Sending TACACS Authorization message. Session id: 375, seq no:1
TACACS Session finished. Session id: 374, seq no: 1
TACACS Request Timed out. Session id: 375, seq no:1
TACACS Session finished. Session id: 375, seq no: 1
I saw that too and that's what made me think it could be a routing issue. Can you do another packet-tracer?
packet-tracer input DMZ udp 10.250.0.5 49 10.250.100.142 49 detail
2378
