particular website is not accessable from LAN
I can't able to access a particular website from LAN eventhough i am able to access all.
Even i tried with static natted ip and there is no result as well.
when i inserted the mux cable directly to my laptop i cud able to access but not throught LAN
I have checked my firewall policy everthing looks ok. If there were certain rules then i would have not able to access more no. 1 site
its a single website i cannot able to access...I tried with static natted ip as well
i did all the troubleshooting but no result.
Is there any1 who had come across with this kind problem.
any help will be appreciated
Khem
Is there any web-filtering server or url-filtering in your network. Also, please get the output of the following command:
packet-tracer input inside tcp (private ip address) 1025 (ip of website) 80 detailed
- Prateek Verma
Thanks 4 the reply
no we dont have any web-filtering server or url-filtering.
I even tried the command u mentioned the output is ok i mean all ok..nothing is being blocked.
is there any other way  to figure out the problem and get it resolved.
Khem
In that we could configure captures on firewall to check the whether it is being dropped due to some policy on firewall or not:
access-list test permit tcp ho (private ip) (ip of site)         -by private ip I mean your source address
access-list test permit tcp (ip of site) (private ip)
capture capi interface inside access-list test
access-list test1 permit tcp (ip of site) (public ip of inside user)
access-list test1 permit tcp (public ip of inside user) (ip of site)
capture capo interface outside access-list test1
Also along with that configure the asp capture:
capture asp type asp-drop all
You could check whether it is being dropped by ASA or not in asp capture by running following command:
show capture asp | in (ip of site)
Then initiate the traffic and check the captures using following command:
show capture capi
show capture capo
- Prateek Verma
hi prateek
i did what u said
after doing the above configuartion
when i do   sh capture capin
sh capture capin
0 packet captured
0 packet shown
but when i hit sh capture capout i getting replied.
Can u suggest what could be the error
Khem,
hello prateek
after seeing the capin and capout
in capin
my ip hitting the webserver but not geting ack from the server
eg  sh capture capin
source ip - 192.168.1.10:55555   203.197.X.X:80
so on
for sh capture capout
source
202.X.X.X:55555 203.197.X.X:80
and so on
i think the problem is m not getiing back the syn ack from the web server
but for all other server geting back the ack from the server
and, i even check the policy and rules as well..
Kindly suggest the best possible way to get rid of this issue.
regards,
Khem
Hi ,
Could you check with the ISP whether that particular websites ip is blocked on their end ? That could be a possibility.
- Prateek Verma
Hi Prateek,
i connected my laptop at router but it is accessable.
i even had a conversation with ISP and they said it is perfect.
when i tried with wireshark to trace the packet.
i came to know that i am not getting back the acknowlege from the server
when i send SYN to server, not getting the ACK(According to the firewall and wireshark)
But when i access the same site from router(directly connected the laptop to router) everything looks perfect.
having problem only to access this particular link.
i did all the troubleshooting which is mentioned by you
sh capture capin
here i m not getting the ACK
sh capture capout
here i am getting ACK from the server
apart from above packet tracer seems ok.
There are no rules as well in firewall
then where is the problem.
thank you 4 responding my issues.
Khem
182
