PC Has Not Met Security Requirement
Hello
We use the WebVPN feature on the Cisco ASA. This works fine but for some users they get a message saying "Login denied. Your PC has not met security requirements"
We have checked there firewall / os /av and they look to be on our approved list.
Is there any logs which will tell us exactly which bit failed?
Anonymous
N/A
Re: PC Has Not Met Security Requirement
Check your computer must meet the following criteria:
• Operating system is Windows XP with Service Pack 2 or Windows Vista. (Macintosh and Linux systems are not being
checked at this time.)
• Microsoft Automatic Software Update turned on so you can receive the latest security patches.
• The latest version of Symantec Anti-Virus with LiveUpdate turned on so you can receive the latest virus definitions.
• A software firewall must be installed and enabled on your computer
Yes we know this but its still failing but we don't know which bit is failing on. There must be some kind of log that tells us exactly which bit it is failing on
131
