Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
permit FTP on ASA 5510 -w- 7.2(10) code
just verified that a host using "XP" desktop using it's CMD in a network created on a 5510 ... say a DMZ ... is not able to FTP out to the Internet. ACL for this DMZ interface is allowing any any outbound. Would the current "ftp mode passive" statement effect this type of request?
thanks, Kevin
1 ACCEPTED SOLUTION
Re: permit FTP on ASA 5510 -w- 7.2(10) code
All ftp connections should negotiate a passive port if a DATA channel can not be opened, if the FTP server is configured for passive connections.
Check your config and check the logs.
HTH>
1 REPLY
HTH>
127
