Phase8 NAT drops
I'm having trouble getting traffic from one sub interface to another.  Logically I know what the issue is, I'm just having issues working through it based on this packet tracer output.
I sit behind the K_Inc interface and need to get to the FOS interface.  There is no ACL to allow the traffic.
You'll have to pardon the santized config, i realize that's a pain, but hopefully it's enough to get me pointing in the right direction
There are routes to my core switch that send traffic for 10/10 to my core from the 192.168.10.0/24 network.
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 7.x.x.21 255.255.255.0
interface GigabitEthernet0/3.10
vlan 10
nameif K_Inc
security-level 100
ip address 192.168.10.254 255.255.255.0
interface GigabitEthernet0/3.177
vlan 177
nameif FOS
security-level 100
ip address 192.168.177.254 255.255.255.0
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
global (outside) 1 interface
nat (K_Inc) 1 10.0.0.0 255.0.0.0
nat (FOS) 1 192.168.177.0 255.255.255.0
static (FOS,outside) 7.x.x190 192.168.177.10 netmask 255.255.255.255
static (FOS,outside) 7.x.x.191 192.168.177.5 netmask 255.255.255.255
static (FOS,outside) 7.x.x.192 192.168.177.9 netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 7.x.x.1 1
route K_Inc 10.0.0.0 255.192.0.0 192.168.10.252 1
packet-tracer input K_Inc tcp 10.10.80.49 1065 192.168.177.10 3389 det
yields:
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xb88abc98, priority=1, domain=permit, deny=false
        hits=253726471, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.177.0   255.255.255.0   FOS
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0xb88ac280, priority=2, domain=permit, deny=false
        hits=667120, user_data=0x0, cs_id=0x0, flags=0x3000, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xb88adb60, priority=0, domain=permit-ip-option, deny=true
        hits=13897343, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 6
Type: FOVER
Subtype: standby-update
Result: ALLOW
Config:
in  id=0xb88ab3b8, priority=20, domain=lu, deny=false
        hits=7400090, user_data=0x0, cs_id=0x0, flags=0x0, protocol=6
Phase: 7
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
static (K_Inc,dmz) 10.10.0.0 10.10.0.0 netmask 255.255.0.0
  match ip K_Inc 10.10.0.0 255.255.0.0 dmz any
    static translation to 10.10.0.0
    translate_hits = 48365, untranslate_hits = 38813
in  id=0xacf39b88, priority=5, domain=host, deny=false
        hits=8592687, user_data=0xacc23618, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=10.10.0.0, mask=255.255.0.0, port=0
Phase: 8
Type: NAT
Subtype:
Result: DROP
Config:
  match ip K_Inc 10.0.0.0 255.0.0.0 FOS any
    dynamic translation to pool 1 (No matching global)
    translate_hits = 44, untranslate_hits = 0
in  id=0xacf4c000, priority=1, domain=nat, deny=false
        hits=43, user_data=0xacf4bf60, cs_id=0x0, flags=0x0, protocol=0
        src ip=10.0.0.0, mask=255.0.0.0, port=0
Result:
input-interface: K_Inc
input-status: up
input-line-status: up
output-interface: FOS
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
What I thought I needed only seems to break my access to the internet:
access-list FOS_In extended permit tcp 10.10.0.0 255.255.0.0 192.168.177.0 255.255.255.0
access-group FOS_In in interface K_Inc
static (FOS,K_Inc) 192.168.177.0 192.168.177.0 netmask 255.255.255.0
static (K_Inc,FOS) 10.10.0.0 10.10.0.0 netmask 255.255.0.0
Thanks in advance!
1 ACCEPTED SOLUTION
Super Bronze
Phase8 NAT drops
But the original traffic wasnt blocked by ACL to begin with. It was dropped because of missing/incomplete NAT configuration.
If you removed the ACL with the "no access-group in interface K_Inc" command this should still work because of
And because of the fact that the interfaces are both "security-level 100"
- Jouni
Super Bronze
Re: Phase8 NAT drops
I imagine that the "FOS_In" ACL contains more rules than this single one? If it doesnt then it naturally doesnt allow the traffic to the Internet as the only allowed destination network is a private network.
By the way, why is the ACL for the interface "K_Inc" named "FOS_In" ?
I would have personally just tried to configure
And tried the "packet-tracer" again.
Seems to me that the traffic originally matched the "nat" statement and had no matching "global" configuration for the destination interface and failed because of that.
So to my understanding the only thing needed is the above "static" and you can leave the out the "access-group" that you added.
- Jouni
Phase8 NAT drops
First thing, I thought of the static NAT first, and it didn't work and I just tried it again, and I get the same result.  It's the same Phase8 nat error.
But I had a very similar issue once before that you helped me with, i was hoping you'd be answering this one.
https://supportforums.cisco.com/message/3999166#3999166
Which is what made me think that traffic isn't allowed.  So I did in fact just fix it, you're first comment above was the key, i did have only the one allow statement to the private network.  Here's what fixed it:
access-list FOS_In extended permit ip 10.10.0.0 255.255.0.0 any
It's only temporary while they migrate some data from one network to the other.
In answer to your question:
By the way, why is the ACL for the interface "K_Inc" named "FOS_In"?
I'm allowing traffic IN to the FOS network, isnt' that appropriate?  Hahaha just kidding.  It was just for me because I'll be ripping it out before the end of the day today anyway.
Thank you.
Super Bronze
Phase8 NAT drops
Are you saying that the problems with the ACL was sorted but the problems with the "packet-tracer" and NAT still remains?
What seems wrong to me in the "packet-tracer" output is the fact that we should see an UN-NAT Phase at the very start if you had this configured while you took another "packet-tracer" output.
It would also seem to me that the original traffic was allowed as there was no ACL configure and the "security-level" values permitted this traffic (same-security-traffic commands + equal security-level)
As I said before, the original output would just seem to point to a situation where you have a "nat" that matches the source address but there is no matching "global" for the destination IP address. To my understanding the "static" command should avoid that problem.
- Jouni
Phase8 NAT drops
Oh man, now I'm confused.
I added this:
and now everything is working.
here's the packet tracer output which shows the packet's allowed, and i can in fact RDP to the server I needed to.
this also now has the UN NAT you were looking for.
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
  match ip FOS 192.168.177.0 255.255.255.0 K_Inc any
    static translation to 192.168.177.0
    translate_hits = 0, untranslate_hits = 1857
NAT divert to egress interface FOS
Untranslate 192.168.177.0/0 to 192.168.177.0/0 using netmask 255.255.255.0
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: FOVER
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
  match ip K_Inc 10.10.0.0 255.255.0.0 FOS any
    translate_hits = 1856, untranslate_hits = 0
Static translate 10.10.0.0/0 to 10.10.0.0/0 using netmask 255.255.0.0
Phase: 8
Type: NAT
Result: ALLOW
Config:
    translate_hits = 51213, untranslate_hits = 40162
Phase: 9
Type: QOS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 11
Type: QOS
Subtype:
Result: ALLOW
Config:
Phase: 12
Type: NAT
Result: ALLOW
Config:
static (FOS,dmz) 192.168.177.0 192.168.177.0 netmask 255.255.255.0
  match ip FOS 192.168.177.0 255.255.255.0 dmz any
    translate_hits = 0, untranslate_hits = 0
Phase: 13
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 14
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 74528300, packet dispatched to next module
Phase: 15
Type: ROUTE-LOOKUP
Subtype: output and adjacency
Result: ALLOW
Config:
found next-hop 192.168.177.10 using egress ifc FOS
adjacency Active
next-hop mac address 0025.9027.a0ae hits 244
Result:
input-status: up
output-status: up
Action: allow
As i said it is working, but I'm a little bit stumped as to why i had to create this acl to allow this traffic considering the same security traffic commands and sec levels.
Super Bronze
Phase8 NAT drops
- Jouni
Phase8 NAT drops
Told you i was confused.  It was just the NATs.
Thank you.
Removed the acl and it all continues to function.
So all i needed was:
You're the best.  Thanks again.
235
