Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ping and traceroute on multiple context mode not working (security appliance)
I can not make work  ping & traceroute in multiple context mode
I have configured two context context1 & context2. the second one have several vlan and servers behind. Then I added the lines below to test if servers behind the security appliance(context2) are on line
access-list outside_access_in extended permit icmp any any time-exceeded log disable
access-list outside_access_in extended permit icmp any any echo-reply log disable
access-group outside_access_in in interface outside
This  works fine in single mode but it seems to have no effect in multiple context mode
is there something missing?
Any ideas?
Hall of Fame Super Blue
Re: ping and traceroute on multiple context mode not working (se
Osavldo
It's a little unclear but echo-reply would presume you are pinging from the servers. If you are trying to ping the servers from the outside then it should be echo-request not echo-reply.
Jon
enable icmp and icmp error inspection on both contexts.
what the logs on both contexts.
Community Member
Ok, thanks very much
I changed my rules to:
access-list outside_access_in extended permit icmp any any traceroute
the ping command now work but not the traceroute
374
