Ping from System Conext in Multi context ASA
Hi Everyone,
ASA has 2 contexts HR which is admin and other context Sales.
When i ssh to HR(admin) and go to system context.
Ping works fine from system context to HR context interfaces and also to nei switch which is connected to context HR amd also to default route
of HR as shown below
ASA5510/HR# sh ip
System IP Addresses:
Interface Name IP address Subnet mask Method
outside OUTSIDE 172.16.1.1 255.255.255.0 CONFIG
Ethernet0/1.26 HR 192.168.26.1 255.255.255.0
ASA5510#                                 ping 172.16.1.2
Sending 5, 100-byte ICMP Echos to 172.16.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/10 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
ASA5510#                                 ping 172.16.1.1
Sending 5, 100-byte ICMP Echos to 172.16.1.1, timeout is 2 seconds:
ASA5510#                                 ping 172.16.1.11
Sending 5, 100-byte ICMP Echos to 172.16.1.11, timeout is 2 seconds:
ASA5510#                                 ping 192.168.26.1
Sending 5, 100-byte ICMP Echos to 192.168.26.1, timeout is 2 seconds:
ASA5510#                                 ping 192.168.26.2
But when i ping to context Sales interface it does not work.
ASA5510# ping 192.168.27.1
Sending 5, 100-byte ICMP Echos to 192.168.27.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
ASA5510# changeto con
ASA5510# changeto context Sales
ASA5510/Sales# sh ip
outside                  OUTSIDE                172.16.1.11     255.255.255.0   CONFIG
Ethernet0/1.27           Sales                  192.168.27.1    255.255.255.128 CONFIG
Current IP Addresses:
Need to know if this is default behaviour?
How does ping traffic flow or work from system context to HR interfaces and to devices connected to context HR?
MAhesh
1 ACCEPTED SOLUTION
VIP Green
This is default behavior.
This is default behavior.  The system context has no interfaces assigned to it and therefore uses an interface in the allocated admin context instead.  Here is a quote for a Cisco document:
The system configuration does not include any network interfaces or network settings for itself; rather, when the system needs to access network resources (such as downloading the contexts from the server), it uses one of the contexts that is designated as the admin context. The system configuration does include a specialized failover interface for failover traffic only.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa72/configuration/guide/conf_gd/contexts.html#wp1133678
This is why you are able to ping networks connected to the HR (admin) context and not the Sales context.
Please remember to select a correct answer and rate helpful posts
-- Please remember to rate and select a correct answer
VIP Green
VIP Green
Keep in mind that the
Keep in mind that the document I referenced is for ASA version 7.2, but the logic remains true for all multicontext ASA firewalls.
86
