Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
PING work TRACEROUTE NOT !!!!! on ASA
I have ASA 5505 from my LAN i can ping internet devices but i cant Traceroute !!
I tried everything i found in cisco:
1- ACL: i allowed all kind ICMP , IP, UDP , TCP in Inside and outside
2- ICMP Inspect
3-set connection decrement-ttl
my lan device is UNIX
and attached my SHOW RUN
Silver
Re: PING work TRACEROUTE NOT !!!!! on ASA
Can you remove access-list bound to inside interface and then try.
no access-group inside_access_in in interface inside
Also check following link :
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml#asatrace
Saju
Pls rate helpful posts
Silver
You need to understand a couple of things:
1- Windows machine uses icmp for traceroute by
default,
2- Unix/Linux machine uses udp high-ports for
traceroute by default,
Why don't you use the "-I" option in traceroute
for linux for icmp instead of udp-high ports?
gen2linux ~ # traceroute -n -I 4.2.2.2
traceroute to 4.2.2.2 (4.2.2.2), 30 hops max, 40 byte packets
1 129.174.155.250 0.309 ms 0.206 ms 0.195 ms
2 129.174.4.129 3.193 ms 2.826 ms 0.998 ms
3 129.174.9.1 159.005 ms 148.492 ms 152.521 ms
4 129.174.251.82 154.987 ms 111.564 ms 144.132 ms
5 129.174.250.27 147.177 ms 143.264 ms 144.186 ms
6 129.174.1.210 34.151 ms 25.372 ms 36.665 ms
7 74.125.192.225 148.354 ms 159.467 ms 189.548 ms
8 64.94.0.79 176.558 ms 156.185 ms 131.922 ms
9 129.250.12.37 37.069 ms 40.620 ms 32.535 ms
10 129.250.3.18 56.812 ms 48.983 ms 50.089 ms
11 129.250.2.169 53.516 ms 50.631 ms 48.474 ms
12 4.68.63.185 132.935 ms 154.625 ms 145.812 ms
13 4.68.17.62 155.658 ms 160.607 ms 158.843 ms
14 4.68.121.13 182.012 ms 195.269 ms 182.375 ms
15 4.2.2.2 167.026 ms 138.771 ms 158.681 ms
gen2linux ~ #
i tried traceroute -n -I 4.2.2.2 and its the same,... ****
i add inspcet icmp error and same traceroute doesnot work
i also remove the ACL on inside interface and nothing happen
its driving me crazy!!!
and here the new sh run
451
