PIX 501 configuration with Cable modem
How do you configure the outside interface to receive its IP address from a dhcp server? (in this case, from a cable modem)
I have a 501 PIX running 6.3.5
Also, after you configure the outside interface for dhcp, how do yu configure the route so everyone on the inside can see the internet?
1 ACCEPTED SOLUTION
Re: PIX 501 configuration with Cable modem
Version 6.x:
ip address outside dhcp setroute
Remove any default gateways from your config.
7.x/8.x:
int eth0/x
ip address dhcp setroute
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806c1cd5.shtml#client
Please rate if helpful
Farrukh
Version 6.x:
7.x/8.x:
int eth0/x
Farrukh
It worked!!....
I don't know why the route statement has to be ommited, but works...
thank you very Farrukh
244
