Pix 501 ftp port forwarding troubles~!
Hello, all. I am having a surprising amount of trouble getting my PIX 501 to do port forwarding correctly to expose my internally-hosted FTP site to the outside world.
My FTP server is on 192.168.1.200 and has been added to my PIX as a named host of WAServ2003 as you can see from my config dump (follows).
After spending way too much time on trying to puzzle my way thru this challenge, can anyone spot any problems from my config dump here?
Appreciate any comments/ideas. Thanks in advance.
-Steve B.
java.util.regex.Matcher[pattern=[a-zA-Z0-9_+-.]+@[a-zA-Z0-9][w.+-]+.[a-zA-Z]{2,} region=0,2640 lastmatch=sbohlen@gmail.com]
Building configuration...
PIX Version 6.1(4)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password XXXX
encrypted
passwd XXXX encrypted
hostname pixfirewall
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
name 192.168.1.200 WAServ2003
access-list outside_access_in permit tcp 64.248.63.128 255.255.255.128 eq ftp host 64.248.63.140 eq ftp
pager lines 24
logging on
logging console debugging
logging buffered informational
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside 64.x.x.140 255.255.255.128
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location WAServ2003 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface ftp WAServ2003 ftp netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 64.248.63.129 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd dns 216.175.203.50 216.175.203.59
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain watsonandassociates.com
dhcpd auto_config outside
terminal width 80
Cryptochecksumxxx
: end
[OK]
Green
Re: Pix 501 ftp port forwarding troubles~!
Get rid of the source port in your acl...
access-list outside_access_in permit tcp 64.248.63.128 255.255.255.128 host 64.248.63.140 eq ftp
or
access-list outside_access_in permit tcp 64.248.63.128 255.255.255.128 interface outside eq ftp
Please rate helpful posts.
good point (and thanks) but I just did that and still cannot get it; any other ideas re: what might be wrong here...?
Green
Want to post the new config?
Are you trying to ftp from 64.248.63.128 255.255.255.128?
I have a question. when you have assigned the IP address 64.248.63.140 255.255.255.128 to the interface doesnt it mean access from internet to the Network segment 64.248.63.128/25 will be pointing towards this interface?
please try modifying the ACL from
to
access-list outside_access_in permit tcp any eq ftp host 64.248.63.140 eq ftp
or
access-list outside_access_in permit tcp eq ftp host 64.248.63.140 eq ftp
Thanks, AJ
Changes made but still no-joy.
This must be something incredibly simple, since it sure looks OK to me.
Other thougths?
New config reads....
: Saved
PIX Version 6.1(4)
enable password XXXX encrypted
names
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
dhcpd dns 216.x.x.50 216.175.203.59
dhcpd lease 3600
terminal width 80
Cryptochecksum:xxx
: end
[OK]
Green
no access-list outside_access_in permit tcp 64.248.63.128 255.255.255.128 host 64.248.63.140 eq ftp
no access-list outside_access_in permit tcp any eq ftp host 64.248.63.140 eq ftp
access-list outside_access_in permit tcp any host 64.248.63.140 eq ftp
Green
You do not want to put a source port in the acl...it will never match.
Thanks everyone for the speedy feedback, but following all these steps I still get no luck on ftp to 64.x.x.140 from anywhere outside my network.
FTP server confirms responding to 192.168.1.200 from INSIDE the network just fine so that isn't the trouble (issue is def. with the config on the PIX *somewhere*).
Here is my updated config. I have also applied the ACL to the interface useing the access-group settings (seen below) but that seems to make no diference either.
Further suggestions?
PIX Version 6.1(4)
names
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
ip address outside 64.248.63.140 255.255.255.128
pdm history enable
arp timeout 14400
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
dhcpd lease 3600
terminal width 80
Cryptochecksum:xxx
: end
[OK]
Hi try,
access-list outside_access_in permit tcp any interface outside eq ftp
I hope it helps .. please rate it if it does !!!
Adding a NAT for port 20 should work:
static (inside,outside) tcp interface 20 WAServ2003 20 netmask 255.255.255.255 0 0
Tim
343
