Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
PIX 501 Help....asap.
Ok so here is my config...
ip address outside 78.xxx.xxx.16 255.255.255.248
ip address inside 10.xxx.xxx.81 255.0.0.0
route outside 0.0.0.0 0.0.0.0 78.xxx.xxx.18
interface ethernet0 100full
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
access-list inbound permit icmp any any
access-list inbound permit tcp any host 78.xxx.xxx.15 eq www
access-list inbound permit tcp any host 78.xxx.xxx.15 eq 53
access-list inbound permit udp any host 78.xxx.xxx.15 eq 53
access-group inbound in interface outside
static (inside,outside) 78.xxx.xxx.15 10.xxx.xxx.83 netmask 255.255.255.255 0 0
access-list inbound permit tcp any host 78.xxx.xxx.14 eq www
static (inside,outside) 78.xxx.xxx.14 10.xxx.xxx.15 netmask 255.255.255.255 0 0
Basically I have 2 servers running behind my PIX with the external IP addresses of 78.xxx.xxx.15 and 78.xxx.xxx.14. I can ping the inside interfaces but I can not ping the outside interface of the PIX, let alone the gateway which is at 78.xxx.xxx.18. I need to have this up and running ASAP, so any suggestions would be great!
Thanks!
Gold
Re: PIX 501 Help....asap.
you can't ping the outside interface from the inside, and vice versa...
you need to add the following to permit icmp replies from the gw....
access-list inbound permit icmp any any echo-reply
or
access-list inbound permit icmp host 78.x.x.18 any echo-reply
you get the idea...
Community Member
Thanks for the repay srue. I guess I should have elaborated a little further... I am not even able to access the internet, that is my main goal. Any advice?
Green
Can you ping the gateway from the pix?
Community Member
What is understand for the problem it seems like you are trying the ping the outside interface from the inside,If i am understanding correctly ..
By design you will not be able to ping the outside interface ..and if you are trying to ping the outside interface from the outside world then please check if its getting denied by ICMP command ..
show ICMP
Community Member
Let us know if you are able to ping the gateway ip address and also let me know if you are trying to access internet from these 2 servers only..But if you are trying to access from other workstations then you need the make the use of nat and global command..
nat (inside) 1 0 0
global (outside) 1 interface
Community Member
Please post the full config of your firewall then we can help easily
Cheers,
MM
P.S. Don't forget to rate replies ;)
Community Member
Here is the running config of the pix...
PIX Version 6.3(1)
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list inbound permit tcp any host 78.xxx.xxx.15 eq domain
access-list inbound permit udp any host 78.xxx.xxx.15 eq domain
access-list inbound permit tcp any host 78.xxx.xxx.15 eq pptp
access-list inbound permit tcp any host 78.xxx.xxx.14 eq pptp
pager lines 24
mtu outside 1500
mtu inside 1500
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 78.xxx.xxx.15
global (outside) 2 78.xxx.xxx.14
nat (inside) 1 10.xxx.xxx.83 255.255.255.255 0 0
nat (inside) 2 10.xxx.xxx.85 255.255.255.255 0 0
static (inside,outside) 78.xxx.xxx.14 10.xxx.xxx.85 netmask 255.255.255.255 0 0
route outside 0.0.0.0 0.0.0.0 78.xxx.xxx.18 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
It is just the two servers accessing the internet, and yes I found that I can ping the gateway. I'm still stumped with this whole thing so keep the help come'n guys...
Thanks!
Community Member
ok you don't do a global and then a static nat that way. All you need to define is a global for the other clients behind the gateway to the interface of your PIX, and then statics for the servers. changes as follows:
Remove these:
Add this:
nat (inside) 1 0.0.0.0 255.0.0.0 0 0
also create an access list for outbound access and put deny ip any any log at the end of boths lists for monitoring purposes etc
Cheers,
MM
Community Member
sorry that nat (inside) command should read:
nat (inside) 1 10.0.0.0 255.0.0.0 0 0
Community Member
mightymouse2045, thanks for the quick responce.
Okay so I changed the config, but now I'm beginning to think I have something with the internal IP addresses wrong. I should have been more clear about what I said before... I can ping the gateway from the PIX, but not from the server. I'm thinking it has something to do with the netmask, my internal is 255.0.0.0 and my external is 255.255.255.248. Although I thought that nat was soposto take care of that?
Thanks!
Community Member
If this helps clarify things:
Gateway - 78.xxx.xxx.18
PIX internal - 10.xxx.xxx.81
PIX external - 78.xxx.xxx.16
Server 1 internal - 10.xxx.xxx.83
Server 2 internal - 10.xxx.xxx.85
Server 1 external - 78.xxx.xxx.15
Server 2 external - 78.xxx.xxx.14
Thanks!
Community Member
by default pings are not allowed through PIX's so you have to enable that by adding in the permit ICMP into your access lists:
So add this into your inbound\outbound access lists:
access-list name permit icmp any any
Once you've added these in try and ping and let me know how you go. Also to restrict the ping on the outside interface you should only really add in specific ping responses like echo-reply, time-out etc do a help on the command for possible responses
Community Member
Okay I just added those access-lists and I and still not able to ping the gateway. But this time I do get a 'Request timed out' as a responce...
Community Member
ok can you try pinging www.google.com and see if you can resolve it and ping it - if yes then you know your working.
If not I'll have another browse through your config - can you post the updated config again too
Community Member
Okay I can ping google's IP address (64.233.161.104) from the PIX, but not from the server. Once again here are all of the IP addresses I am using:
These are web servers, so server 1 has to have the external IP of .15 and server 2 has to have the external IP of .14.
Thanks again for your help!
Community Member
yep which was achieved with the other commands i told you to add in.
Can you post your updated config as it appears now?
Community Member
Hey I actually entered in one of the commands wrong that you gave me, I corrected it any am now able to ping google's IP. I am still having a DNS issue though, I cannot ping www.google.com, just the IP. Also here is my updated config... and suggestions for security?
PIX Version 6.3(1)
names
access-list outbound permit icmp any any
pager lines 24
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
Thanks again 2040!
Community Member
ok you need to apply the outbound access list to the inside interface:
access-group outbound in interface inside
Also where are your DNS servers? Are you running DNS on your internal servers, or you have your internal clients\servers all pointing to your external DNS servers?
Let me know which one and I'll tell you the rules to add in to allow the DNS traffic. Also what access do you want internal servers\clients to have to the internet - or is it purely to allow external clients to access web services and pptp on the internal servers?
Cheers,
MM
Community Member
Okay the DNS servers are currently external, but once everything is configured I will be running them on the internal servers. As far as access is concern, I would like everything to be as secure as possible, the internal servers must be able to access the internet, infact I really have no need to restrict anything on them. Outside should only be able to view the web data on the servers. I have the pptp ports open to configure the servers remotely.
Thanks!
Community Member
ok so probably just best to add in:
access-list outbound permit ip 10.0.0.0 0.255.255.255 any
You already have the inbound access list setup correctly so that should be about it.
So once you add in that permit any command try DNS resolution again - if it's not working check you have the correct DNS servers setup and try pinging them.
If they are setup correctly and you can ping them - then add a deny ip any any log to the end of each access list and set logging to 7 and monitor the output on the console as you are doing nslookups and see if anything is being blocked
Cheers,
MM
P.S don't forget to rate the responses ;)
Community Member
Ok so I entered the access list in, and was able to ping the DNS servers, but I am still not able to ping www.google.com or bring up a website. I set the logging monitor to 7 and tried to open a website, but when I went to view the logging it says '0 messages logged'... any idea?
Thanks!
Community Member
sorry to be a pain but can you post in the config as it looks now :)
Community Member
PIX Version 6.3(1)
names
access-list outbound permit ip host 10.0.0.0 any
access-list out deny ip any any log
access-list in deny ip any any log
pager lines 24
logging on
logging monitor debugging
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
access-group outbound in interface outside
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
Community Member
ok do this:
1. Remove these lines:
2. add these lines:
access-list outbound permit ip 10.0.0.0 255.0.0.0 any
access-list outbound deny ip any any log
access-list inbound deny ip any any log
access-group inbound in interface inside
3. Also are you sure your subnet mask for the external interface is correct? Because .16 address is the network address for the range .16 to .23 with .17 to .22 being usable.
The IP you have setup with .15 is actually the broadcast address of the subnet below .16, and .14 is the last usable in that subnet range.
Who assigned the IP addresses for you and what range and other details did they give to you?
Cheers,
MM
Community Member
Yes they are correct, I changed the external addresses because I'm posting on a public forum. The subnets are correct, just not the IPs.
I entered the updates, and I'm still getting the same thing. '0 messages logged' and I'm still at the same point with the DNS.
Here is the updates config...
PIX Version 6.3(1)
names
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
Thanks again!
Community Member
ok you have these around the wrong way:
Remove them and add them as:
Community Member
Okay that didn't work. Here is exactly what I'm entering into the PIX, maybe this will help:
hostname xxxxxxxxxx
ena password xxxxxxxxxxxxx
access-list inbound permit tcp any host 78.xxx.xxx.15 eq 1723
access-list inbound permit tcp any host 78.xxx.xxx.14 eq 1723
logging on
logging monitor 7
Thanks mightymouse !
Community Member
you've got the access-group inbound stated again down the bottom to the wrong interface again.
Save the config (wr mem) and have a look at it on the pix - does it come up with:
The best way to edit in bulk is to save the config on the device then copy it to a tftp server (copy start tftp) edit the config file in notepad (word wrap turned off), save it and then copy it back to the startup-config on the pix via tftp (copy tftp start) and restart the pix.
Cheers,
MM
Community Member
Okay well I'm at a loss... I'll keep looking around to see what I can find, but I'm still in the same situation. Thanks for getting me to where I'm at!
175
