PIX 501 - routing and NAT capability question
olighec
I have a PIX 501 on order, but I want to know before I get it:
- Can the PIX 501 support routes to multiple noncontiguous IP subnets over a single tunnel? (i.e. routing 172.16.0.8/29 and 10.0.0.0/8 over the same tunnel)
- Can the PIX 501 support multiple NAT addresses on the same interface (i.e. one overloaded address and 4 or 5 static entries)
Chris
CSCO10723456
Hi Chris,
both are totally doable, for the first you will need to specify two lines in the crypto access list each for a seperate network.
and the other one is simple and straight forward and easily done ;)
regards,
Shadi`
Great, Thanks!
