Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Pix 506e - 1721 connection problem
Hi all,
I need to change my border router to a 1721 with one sdsl and one adsl
interface. This then connects to a pix 506e but the 1721 has been
configured with public ip's on the wan's (each ip is from a different
range) they are then nated on the fa to a private ip.
My problem - is that the pix 506e has a public ip and is configured to
deal with various operations which need a public ip. So the fa int on
the router needs to have a public ip and no nat.
someone has suggested virtual int's on both pix and router ??
is this possible ?
Many Thanks
Alex
ps Ive posted the config from the router
1 REPLY
Silver
Re: Pix 506e - 1721 connection problem
It will be better if you do NAT on PIX and not on the router.This way you can put the fa interface of router on a public ip address and connect this to the PIX. I don't think using virtual interfacs will solve your problem.
113
