Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
PIX 506e and Moneris Debit Terminals
Ok, newbish to cisco stuff, just put in a new 506e. Everything is working so far, except now my high speed debit/credit terminals will not communicate through the router. Moneris says port 443 has to be "open". Well, it is, isn't it? I can check my account balance online, which is a secure https connection, with no problems. Do i need to create 2 specific rules to allow traffic on that port to those terminals?
Thank you for your time.
Maury
Re: PIX 506e and Moneris Debit Terminals
What's the direction of the TCP/443 traffic? From the outside to the inside or from the inside to the outside?
Well, thats a good question. I'm assuming its outside to inside, which should have no issues. We swipe the debit card, and it contacts a server somewhere, then sends back a reply. But, its not communicating properly, so it reverts to the dial backup. I can ping from the terminal, but its communication to its server is not functioning.
What does your NAT setup look like?
sh nat
sh global
Feel free to sanitize the output if you need to.
Not much to sanitize really :)
sh nat
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
sh global
global (outside) 1 interface
"Well, thats a good question. I'm assuming its outside to inside, which should have no issues."
I beleive i meant "inside to outside", sorry if that caused any confusion.
Green
So it's...
Terminals -> Inside PIX -> Outside PIX -> Internet -> Server
Is this traffic from the terminal to server go over vpn or is that nat exemption for something else?
I have a VPN setup using the Pix and the cisco VPN client. This will be for my remote users to use for remote access so i can lock down the rdp ports currently used.
Looks like it was an issue with one of my wireless bridges not getting rebooted after the new router install.
Thanks for the effort though!
Maury
536
