PIX 506E PDM issues
Hi all,
I am starting a new job, and one thing that needs to be done asap is to set up a PIX 506E firewall.
I admit it has been some time since configuring a PIX, so i thought i would use the GUI to enter the basics (needs to be just up and running asap), and come back to it after in CLI mode and do it properly.
I have set the inside IP to 192.168.0.50 to configure it, and have set an attached PC to 0.51 and connected it to the inside port.
When i go to configure it (punching https://192.168.0.50 into my web browser), it gets to the log on screen, i can log on ok, but then throws up an error when trying to load PDM V4.1: 'Cisco PDM 4.0 for FWSM does not work on the PIX. Please install Cisco PDM 3.0 on your PIX'
As i understand it, the 506E has PDM V3.0 designed for it? Is there a way around this issue? I do know the firewall was in use previously with this IOS and PDM.
Everyone's tags (2)
Re: PIX 506E PDM issues
According to the documentation:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm23/pdm41/configuration/guide/pdm40CH1.html
The PIX indeed does not support 4.1
Is there a reason you don't want to install PDM 3 on the PIX? Should be a fairly easy TFTP to the device
http://www.cisco.com/en/US/docs/security/pix/pix63/pdm30/installation/guide/pdm30CH2.html
I am just assessing the PIX at the moment, i have not added or removed anything from it. if it needs fixing though, i will certainly do it.
I am not sure how 4.1 got onto it, but the IOS is 6.3(5):
pixfirewall# sh ru
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
So should be good to load PDM V3.0 into it?
Also, am i able to download PDM V3.0?
PDM 3.04 should be the one to run, to download it, use the link below (assuming you have permissions for your account for SW downloads)
http://www.cisco.com/cgi-bin/Software/Tablebuild/doftp.pl?ftpfile=cisco/ciscosecure/pix/pdm-304.bin&app=Tablebuild&status=showC2A
1786
