PIX-515 interface errors
We have a physical interface that has 2 vlans on it. On show interface, there is the following:
21450335 invalid VLAN ID errors, 61212 native VLAN errors
The invalid VLAN ID errors are incrementing by about 120 a minute....does anyone have any ideas what causes them? There's nothing in the logs. Is it a config problem on a host?
J
Re: PIX-515 interface errors
hello J,
Can you post us the configs please? probably there are some mismatches on the native vlan configured on the switch and the PIX firewalls... usually on a well-configured PIX, u will not get such errors... First, make the switch with plain configs (only configure trunk) and see if u get these errors...
Raj
Many thanks Raj for your response.
Well here is a section of the config:
interface ethernet1 100full
interface ethernet1 vlan30 physical
interface ethernet1 vlan1 logical
nameif ethernet1 A security100
nameif vlan1 B security85
ip address A 192.168.1.0 255.255.255.0
ip address B 192.168.2.0 255.255.255.0
Unfortunately this is a live environment so I can't play around with it.
Any idea what the errors indicate?
J
Bronze
Well, the pix considers the physical interface the 'native' vlan - are you sure the native vlan configured on the trunk is vlan 30?
I'm assuming that the 192.168.1.0 network is working?
Also - can you send us the configuration for that portion of the switch (the trunk?)
--Jason
Hi Jason,
Many thanks for your response.
The native vlan on the trunk port is 1 (default). Do you think that's where the problem lies - for VLAN ID errors and native ID errors?
interface FastEthernet1/0/1
switchport mode trunk
no logging event link-status
duplex full
speed 100
no snmp trap link-status
no mdix auto
end
Thank you,
J
132
