PIX 515 Will Not Read Flash Image
Use BREAK or ESC to interrupt flash boot.
Use SPACE to begin flash boot immediately.
Flash boot in 8 seconds.
Can not use esc or break, it just keeps looping back to:
Re: PIX 515 Will Not Read Flash Image
when using brake to interupt boot can you get to rommon> prompt? sounds you may need to upload new image.
it does nothing when I use brake, it just tries to load the falsh and then loops back
try to use ESC key and then see what happend
I have tried the esc key also
I think the problem is at confreg file.
Try to use BREK+SHIFT ore BREAK+CTRL
Have you tried changing the DRAM out? I've seen DRAM go bad in a 515 and it would cause something like this. The only other time I have seen this is with a dead 515.
-brad
www.ccbootcamp.com
(please rate the post!)
145
