PIX 515E Config Help!!!
I just got my PIX515e configured and thought I had it working correctly, but on my 3745 router, the line protocol is down, I've looked through the configs for bot the PIX and the 3745 and can't seem to figure out why I don't have access. Would anyone be able to please help resolve the issue for me?
Pix515E config:
pixfirewall# show run
: Saved
PIX Version 8.0(4)32
hostname pixfirewall
domain-name home.jkkcc.com
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet1
nameif inside
security-level 100
ip address 10.0.20.1 255.255.255.248
interface Ethernet2
nameif DMZ
security-level 50
ip address 10.0.30.1 255.255.255.248
ftp mode passive
dns server-group DefaultDNS
pager lines 24
mtu outside 1500
mtu inside 1500
mtu DMZ 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside) 1 0.0.0.0 0.0.0.0
router eigrp 1
network 10.0.0.0 255.0.0.0
network 192.168.0.0 255.255.255.0
network 192.168.2.0 255.255.255.0
network 192.168.4.0 255.255.255.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
no snmp-server location
no snmp-server contact
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect http
  inspect ils
service-policy global_policy global
prompt hostname context
Cryptochecksum:c7359e3905dd13a5aa1a1c0e85a91f52
: end
3745 Config:
3745-Internet#show run
Building configuration...
Current configuration : 2248 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
hostname 3745-Internet
boot-start-marker
boot system flash:
boot-end-marker
no logging buffered
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
memory-size iomem 25
no network-clock-participate slot 2
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1 192.168.2.150
ip dhcp pool HOME-Network
   default-router 192.168.2.1
   dns-server 192.168.2.127 192.168.1.128
ip dhcp pool home-network
ip domain name www.jkkcc.com
ip name-server 192.168.2.127
parameter-map type regex sdm-regex-nonascii
pattern [^\x00-\x80]
username woodjl1650 privilege 15 password 0 henry999
archive
log config
  hidekeys
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address 10.0.20.2 255.255.255.248
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface Serial0/0
description $FW_INSIDE$
ip address 10.0.10.1 255.255.255.248
ip nat inside
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
ip address 10.0.10.2 255.255.255.248
ip nat inside
router eigrp 1
network 10.0.0.0
network 192.168.0.0
network 192.168.2.0
network 192.168.4.0
auto-summary
no ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 15 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.2.21 80 interface FastEthernet0/0 80
ip nat inside source list 104 interface FastEthernet0/0 overload
access-list 15 permit 10.0.8.0 0.0.7.255
access-list 15 permit 192.168.4.0 0.0.0.255
access-list 104 permit ip any any
snmp-server community public RO
snmp-server community private RW
snmp-server enable traps tty
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
transport input telnet
webvpn cef
end
Everyone's tags (4)
Jonathan,
Line protocol on which Interface? If it is connected to the switch, the problem is between the switch and the Router isnt it? Can you send the interface configuration of the switch?
Mike
Mike
Re: PIX 515E Config Help!!!
No it's connected directly, should I use a crossover cable? No switch is used between the pix and router.
Line protocol down in the router, F 0/0
Jonathan,
You can try the crossover but if both units are on auto/auto, MDI should kick in and that shouldnt be a problem.
Mike
Mike
Ok, changed a few things around and I am able to connect my router via a switch to the PIX.  Everything works fine, except no internet access...  Is my config right on my PIX?
names
interface Ethernet0
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
nameif DMZ
security-level 50
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
mtu DMZ 1500
arp timeout 14400
router eigrp 1
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect http
  inspect ils
Cryptochecksum:281e59da1b419753a5c01dcb9b443070
Missing the following:
Global (outside) 1 interface
Try with TCP traffic not with icmp.
Mike
Mike
Still can't access the internet from my inside network, I can ping 8.8.8.8 (google DNS) from the pix... Any ideas
Never mind, got it...no default route on the router...
Last question: ASDM...
I have the file in flash, asmd image command was issued, HTTP server enabled, but still can't access the ASDM, any thoughts?
You need to specify who is going to access it.
For example, host 10.0.20.12 that is on the inside. Issue the following command.
http 10.0.20.12 255.255.255.255 inside
If you want all the inside to access it
http 0 0 inside
Mike
Mike
Everything seems to be working fine now, except one last issue.  I can ping my exchange server.  Do you see anything wrong or why my ping would not go through?  I can ping 10.0.20.1 (Pix Ethernet 1) and I can ping from all my computers to the 10.0.20.1 but not I get this when trying to ping 10.0.30.1
C:\Users\Exchange>ping 10.0.30.1
Pinging 10.0.30.1 with 32 bytes of data:
Reply from 10.0.30.3: Destination host unreachable.
Reply from 192.168.2.1: Destination host unreachable.
Ping statistics for 10.0.30.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Exchange = 10.0.30.3 255.255.255.248
Pix Ethernet 2 (exchange) = 10.0.30.1 255.255.255.248
Current Config:
enable password DQucN59Njn0OjpJL encrypted
passwd DQucN59Njn0OjpJL encrypted
names
interface Ethernet0
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
nameif exchange
security-level 100
ftp mode passive
dns domain-lookup inside
name-server 192.168.2.22
access-list inbound extended permit tcp any host 68.224.242.13 eq www
access-list inbound extended permit tcp any host 68.224.242.13 eq smtp
pager lines 24
mtu outside 1500
mtu inside 1500
mtu exchange 1500
icmp deny any outside
asdm image flash:/asdm-61551.bin
arp timeout 14400
global (outside) 1 interface
nat (exchange) 1 0.0.0.0 0.0.0.0
static (exchange,outside) tcp interface smtp 10.0.30.3 smtp netmask 255.255.255.
255
router eigrp 1
http server enable
http 0.0.0.0 0.0.0.0 inside
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect http
  inspect ils
Cryptochecksum:3672d254988d246453e4be381a198858
: end
pixfirewall#
1767
