Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
pix 515e does not start
The boot sequence stop at this point:
CISCO SYSTEMS PIX FIREWALL
Embedded BIOS Version 4.3.207 01/02/02 16:12:22.73
Compiled by morlee
128 MB RAM
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 00 00 8086 7192 Host Bridge
00 07 00 8086 7110 ISA Bridge
00 07 01 8086 7111 IDE Controller
00 07 02 8086 7112 Serial Bus 9
00 07 03 8086 7113 PCI
00 0D 00 8086 1209 Ethernet 11
00 0E 00 8086 1209 Ethernet 10
00 11 00 11D4 2F44 Unknown Device 11
00 13 00 8086 B154 PCI-to-PCI Bridge
01 04 00 8086 1229 Ethernet 11
01 05 00 8086 1229 Ethernet 10
01 06 00 8086 1229 Ethernet 9
01 07 00 8086 1229 Ethernet 5
Then I try to power-on in monitor mode but when type the escape only test menu appear:
128 MB RAM
Testing mode menu:
1. Test floating point. 13 00 8086 B154 PC
2. Test protected mode.
3. Exhaustive Test first 640k.REWALL
*. Start all tests (Any key to stop tests).
4. Exhaustive Test high memo
C. Continue.
All test is Ok.
How do I start in monitor mode ?
Many thanks
Re: pix 515e does not start
Fausto, when booting you should get the option of two text messages .
e.g
"Use BRAKE or ESC to interrupt flash boot "
or
"Use SPACE to bigin flash boot immediately "
do you see this text at all ? if you see these two text messages use the ECS key to go into monitor mode.
Community Member
when I power-on the pix the only text that appear is:
Compiled by morlee
128 MB RAM
PCI Device Table.
00 07 03 8086 7113 PCI Bridge
if I press Esc button during this step the test menu appear, otherwise the pix remain frozen without load image.
299
