Pix 515E multiple subnets on outside interface
Can you have multiple subnets on the outside of a Pix 515E with 6.3(3)? I have run out of addresses and adding a subnet would take much less configuration changes. I have a 2801 router with a T1 card with the Pix 515E behind it. If I just set up the routes for new public subnet on the 2801 and setup on the outside of the Pix the Nat and acls for the different subnet would it then be pingable etc.?
Hall of Fame Super Blue
Re: Pix 515E multiple subnets on outside interface
If i understand correctly then yes you can use another subnet on your pix for NAT etc. As long as the subnet your are using gets routed to the outside interface of your pix then it should all work fine.
We have done this a number of times where i work.
Jon
Have you any experiance of implementing this in a Failover environment, are there any additional issues to be aware of?
Hi Mark
Yes it works in a failover environment as well. There are no additional issues i have come across. All you are doing is setting up static statements and acl rules for this additional subnet and these are automatically updated to the failover device.
Your routing to this subnet just points to the IP on the outside interface of the active Pix which gets transferred in failover anyway.
Jon
144
