PIX 515e Static NAT/DMZ Issue
I have a 515e, 6.3(4) with an internal interface and a DMZ. The DMZ interface is 10.0.20.1 and the outside interface is 69.xxx.yyy.188/28
I have setup a web server which is currently the only device in the DMZ. I need to make a static mapping to this box but for some reason I just can't get it to work. The web server's local address is 10.0.20.100 and the public address that I need to statically map it to is 69.xxx.yyy.187/28
Here's my config so far:
interface ethernet0 100full
interface ethernet1 100full
interface ethernet2 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
ip address outside 69.xxx.yyy.188 255.255.255.240
ip address inside 192.168.20.1 255.255.255.0
ip address dmz 10.0.20.1 255.255.255.0
access-list dmz_in permit ip any any
access-list outside_in permit ip host 69.xxx.yyy.187 any
global (outside) 1 interface
global (dmz) 1 10.0.20.110-10.0.20.120
nat (inside) 1 Inside_LAN 255.255.255.0 0 0
nat (dmz) 1 dmz 255.255.255.0 0 0
static (outside,dmz) 10.0.20.100 69.xxx.yyy.187 netmask 255.255.255.255 0 0
access-group outside_in in interface outside
access-group dmz_in in interface dmz
I have the access-lists open for troubleshooting purposes... The global (dmz) statement is temporary so that I can access the DMZ from my inside network.
Any help would be greatly appreciated.
Paul
1 ACCEPTED SOLUTION
Green
Re: PIX 515e Static NAT/DMZ Issue
Haha, no offense you never know who you're dealing with. There was a similar post here within the last few days. I believe it was an arp issue on the isp router. Something to consider.
Paul
You need to make the static mapping from the high security to low security interface:
i.e
static (dmz,outside) 69.xx.yy.187 10.0.20.100 netmask 255.255.255.255
As you are allowing access from a low to high security interface you need an acl which should go as follows:
access-list outside_in permit ip any host 69.xx.yy/187
Above allows access from any ip to your web server.
Regds
Thanks for the reply-
I actually got that line wrong in my posting. I do have static (dmz,outside) and not the other way around.
I did change my access list, as you were correct with that, but it still does not work. The access-list doesn't show any hits, either.
Any other suggestions?
Paul
Green
Post you new config.
Here is the newer config:
access-list outside_in permit ip any host 69.xxx.yyy.187
static (dmz,outside) 69.xxx.yyy.187 10.0.20.100 netmask 255.255.255.255 0 0
Green
Nothing wrong there, clear xlate?
Did it. Still no dice. That's why I'm so confused!
Green
Have you tried using the interface ip instead just to see if that works.
access-list outside_in permit ip any interface outside
static (dmz,outside) interface 10.0.20.100 netmask 255.255.255.255 0 0
This PIX is actually in production right now, and there's no chance that I can do that, at least during business hours...
P
Green
You are trying to hit 69.xxx.yyy.187 from outside the firewall right?
Yes. I'm not THAT much of a newbie!
When inside of the network, however, I notice that as soon as I put in the static command the server loses internet access. It works fine with PAT, but of course then it isn't accessible from the outside.
Green
Hall of Fame Super Blue
It shouldn't make a difference but you do have overlapping NAT statements ie
If the web server is the only device in the DMZ could you not just remove your
nat(dmz) 1 dmz 255.255.255.0 0 0 statement.
Jon
Yeah, I know. I had that there because if I remove the static statement then I can get internet access on the box.
One thing that I just noticed - not sure if it makes a difference - on my internet router if I do a sh ip arp I see the arp from .187 as being incomplete.
Any thoughts?
Mr. Comiskey-
Thanks for all of your help. You actually pointed me in the right direction to find the answer: The other guy that had this issue fixed it by turning on proxyarp. Worked for me too.
no sysopt noproxyarp outside
There it was, all along.
Thanks, guys
Paul
335
