Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
PIX 525 boot problems
When I power on my PIX 525-UR it stops the boot process when it is showing the interfaces on the screen.
I'm sending a screenshot.
What could this be?
Re: PIX 525 boot problems
These kind of errors are usually an indication of hardware failures, but try the following:
> Disconnect all network connections and reboot the appliance, see if it helps.
> Try to do software recovery via rommon is that is an option.
Farrukh
Farrukh,
I've tried to do the software recovery, but PIX stops before I can enter rommon mode...
These people have a similar problem as yours (without a solution tough):
http://www.velocityreviews.com/forums/t33045-cisco-pix-not-responding-please-help.html
Farrukh
272
