Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
PIX 525 - Can't ping inside interface from inside
This is driving me nuts, bc I can't figure it out. Please Help!
I have a new PIX 525.
I'm trying to upgrade the IOS, and can't even ping to get to the PC/TFTP Server.
It's driving me nuts.
I can upgrade it via Monitor Mode, no problem.
But I'm trying to upgrade via "copy tftp flash" command, which won't work if I
can't even ping.
I?m not even trying to go out. Just trying to ping the inside interface from the inside. I?ve got my PC directly connected to the Inside Interface.
Also, this is a Secondary PIX, not the primary. That shouldn?t matter should it?
Any suggestions would be grateful.
PC/TFTP Server (directly connected to PIX Inside interface)
10.107.16.116 255.255.255.0
GW 10.107.16.1
PIX config I entered:
nameif e1 inside sec100
int e1 auto
ip addr inside 10.107.16.118 255.255.255.0
route inside 0 0 10.107.16.116
icmp permit 10.107.16.116 inside
conduit permit icmp any any echo-reply
PIX Config is below:
: Written by enable_15 at 10:18:57.897 UTC Fri Jan 12 2007
PIX Version 6.3(1)
interface ethernet0 auto shutdown
interface ethernet1 auto
interface gb-ethernet0 1000auto shutdown
interface gb-ethernet1 1000auto shutdown
interface ethernet2 auto shutdown
interface ethernet3 auto shutdown
interface ethernet4 auto shutdown
interface ethernet5 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif gb-ethernet0 intf2 security4
nameif gb-ethernet1 intf3 security6
nameif ethernet2 intf4 security8
nameif ethernet3 intf5 security10
nameif ethernet4 intf6 security12
nameif ethernet5 intf7 security14
enable password xxxxxxxxxxxxxxxxx
passwd xxxxxxxxxxxxxx encrypted
hostname PIX525A
domain-name xxx
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
pager lines 24
mtu outside 1500
mtu inside 1500
mtu intf2 1500
mtu intf3 1500
mtu intf4 1500
mtu intf5 1500
mtu intf6 1500
mtu intf7 1500
no ip address outside
ip address inside 10.107.16.118 255.255.255.0
no ip address intf2
no ip address intf3
no ip address intf4
no ip address intf5
no ip address intf6
no ip address intf7
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
no failover ip address intf2
no failover ip address intf3
no failover ip address intf4
no failover ip address intf5
no failover ip address intf6
no failover ip address intf7
pdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community nonpublic
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxxxxxxxxxxxxxxxxx
Thanks to All in advance
Bronze
Re: PIX 525 - Can't ping inside interface from inside
Couple of questions:
Do you get link? (interface shows as up when you do a show int on the pix?)
Are you using a crossover cable?
Do you get an arp entry on the firewall for you PC (assuming the first 2 questions are yes) ?
Have you confirmed that your PC has the correct IP address and subnet mask?
--Jason
Please rate this message if it helped solve some or all of your issue
Jason,
Yes, get link light, and when I pink from PC, I can see activity light on the Inside Int.
No, no crossover cable, only straight through being used.
Yes, PC has 10.107.16.116 24 bit mask.
PIX, has 10.107.15.118, 24 bit mask.
No, Arp entry on PIX.
When I enter "sh arp" nothing is replied.
Don
Looking at your statement above-
"Yes, PC has 10.107.16.116 24 bit mask.
PIX, has 10.107.15.118, 24 bit mask."
The PC and the PIX are on different subnets (10.107.16.0 255.255.255.0- PC, 10.107.15.0 255.255.255.0- PIX). Are these IP Addresses/subnet masks accurate? If not, that could be a cause of your problem.
PIX, has 10.107.16.118, 24 bit mask."
Jason,
sorry, my bad, it did pick up the arp from the PC.
I had just powered it up, and the arp was empty, but then it showed up.
637
