Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
PIX 525 upgrade from 6.3 to 7.0: monitor mode or not
Hi, I'd like to upgrade a 525 from 6.3 to 7.0 and but I'm not sure if upgrade in monitor mode is required. The upgrade doc talks about monitor mode for 515 and 535, but it's better to verify
thanks
1 REPLY
Re: PIX 525 upgrade from 6.3 to 7.0: monitor mode or not
you can upgrade your PIX 525 firewall normally through regular "copy tftp flash"
i believe you are mentioning about http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804708d8.shtml#t2
you do not need to upgrade your PIX 525 through monitor/ROMON mode and a normal upgrade will do; however please make sure the firewall meets the minimum system requirements before you upgrade to 7.x code.
I hope you would have already gone through the minimum system requirements in the above link as well.
Do let me know if you have any further questions
463
