Pix 525 Upgrade Help
Hello All,
Im a newby with Security Hardware, and need best practices documents or experience for PIX 525.
This is what i have:
pix_portal# sh ver
Cisco Secure PIX Firewall Version 5.3(3)
Compiled on Wed 09-Jan-02 22:56 by morlee
pix_portal up 1 year 60 days
Hardware: PIX-525, 256 MB RAM, CPU Pentium III 600 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : IRE2141 with 2048KB, HW:1.0, CGXROM:1.9, FW:6.5
0: ethernet0: address is 0008.e2d5.4301, irq 10
1: ethernet1: address is 0008.e2d5.4302, irq 11
2: ethernet2: address is 00e0.b204.fe01, irq 11
3: ethernet3: address is 00e0.b204.fe02, irq 10
4: ethernet4: address is 00e0.b604.fe0d, irq 9
5: ethernet5: address is 00e0.b604.fe0c, irq 5
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES: Disabled
Maximum Interfaces: 8
Cut-through Proxy: Enabled
Guards: Enabled
Websense: Enabled
Throughput: Unlimited
ISAKMP peers: Unlimited
Serial: Ommited
Activation Key: Ommited
pix_portal#
Is there any Device Manager for this Hardware Version ?
Many Thanks,
Petrónio
Re: Pix 525 Upgrade Help
Bruno,
There is no PDM for the 5.x code of sofware as far as I amware. So you need to upgrade if you want the GUI function and all the other nice features an upgrade gives you...if you do plan to upgrade there is some ESSENTIAL reading - go to here for all you need to know:-
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094a5d.shtml
HTH>
Wow, that is some fairly old code. Once you get the unit upgraded to something in the 6.3 train, you are getting better off.
I would not use PDM for anything, ever. PDM does not cover much of the command set and can get your configuration fairly messed up.
I have upgraded PIX 525s 6.3(4) and 6.3.(5) straight to 8.0(3) with very few issues. In one case I had to recreate a single remote user VPN.
Now ASDM, rocks. Use it.
Mike
Thank You for your both replys.
Just a question, is it possible to put the ASDM in a PIX ?
I thought that ASDM was only for ASA ...
Best Resgards,
Petrónio
Yes - ver 7.x and above of PIX IOS supports the ASDM
HTH>
You definately can. It will not work with 501s, 506s and 515 without the memory upgrade. However I have used ASDM on 525s and 535s.
Mike
143
