Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Pix 535 high cpu usage when compiling turbo acl!!! Please help!!
we are an internet provider and use a Cisco Pix 535 failover pair in one of our server farms. The pix version is 6.3(5). Our big problem is that, when we add or modify lines on the turbo access-list, the cpu goes between 90-95% for about 5-10 minutes, causing big connectvity problems to our customers.Our pix has 1024 bytes of Ram.
Could you please give us some hints to reduce this high cpu load? On normal utilization, the cpu is about 25-30%!!
Many thanks!
Daniela
1 REPLY
Bronze
Re: Pix 535 high cpu usage when compiling turbo acl!!! Please he
Refer to the following url which provides the steps to troubleshoot high cpu usge issues with the reason fro the same:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008009491c.shtml#memory
227
