Pix(6.3(3)) to PIX (7.0 or 7.2(2) conversion
Dear all,
I have Pix 520(6.3(3)) and i'd like to replace it with another one PIX525 (7.0 or 7.2(2)) But the problem is in the old config ( Conduit ,Fixup,interfaces , VPN and...)
how can i convert (move) the old config (6.3(3)) to the new one (7.2(2) or 7.0) and what about the activation key or the licence?
Re: Pix(6.3(3)) to PIX (7.0 or 7.2(2) conversion
conduits are the big thing.
You will need to make an access-list containing all of your conduit statements. This access-list will need to be applied inbound on the outside interface using:
access-group in interface outside
Thats the biggest difference, alot of it will be similar. VPN would be another big difference. Check out the "group-policy" command and the "tunnel-group" commands and examples of each if you have VPN's terminating on the device.
yes there are many conduit commands and vpn too .
I have heard aout the tool conversion did u use it?
94
