Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
PIX 7 : Wrong Sequence number in a RST ACK
Hi Everyone,
My Firewall : PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz - Software Version 7.0(4)
My BIG problems :
In a " particular condition ", in answer to an SYN ACK, the PIX send a RST ACK to the server, with an SEQ number of 1 HIGHER than it should be.
Example :
Source : 10.26.50.1 (server) Destination : 10.246.66.227 (client)
Source Port : 80 () Destination Port: 1414 ()
Sequence Number : 2191510856 Ack Number: 680687843
Header Length : 24 Flags: Ack Syn
Source : 10.246.66.227 (client) Destination : 10.26.50.1 (server)
Source Port : 1414 () Destination Port: 80 ()
Sequence Number : 680687844 Ack Number: 2191510857
Header Length : 20 Flags: Ack Rst
Sequence Number : 2191510857 Ack Number: 680687843
Sequence Number : 680687844 Ack Number: 2191510858
The server ignores this and sends out the ACK SYN again and this looping condition continues.
The logging (level 7) on the pix is like this :
PIX- %PIX-6-106015: Deny TCP (no connection) from 10.26.50.1/80 to 10.246.66.227/1414 flags SYN ACK on interface inside
Help me please ...
1 ACCEPTED SOLUTION
Community Member
Re: PIX 7 : Wrong Sequence number in a RST ACK
Are you using the SSM-CSC module in this unit?
Look at the ASA722 release notes. I think one of the caveats it fixes is packets not being reconstructed in proper order. This could be what you're seeing.
1 REPLY
Community Member
550
