PIX and FTP Connection Issue
I have a stand alone Windows 2003 Server set up for FTP.
The server is set up with usernames and passwords required and no anonmymous login allowed.
I can successfully use it from within the office. However from outside of the network it fails to retreive the directory listing. I am receiving the error: "Server sent passive reply with unroutable address. Using server address instead".
In the PIX Config I have the following lines:
access-list outside extended permit tcp any host 192.168.5.5 eq 31
static (inside,outside) tcp 192.168.5.5 31 154.56.76.12 31 netmask 255.255.255.255
Public IP of Server: 192.168.5.5
Internal IP of Server: 154.56.76.12
Any ideas on what I am missing would be great.
Thanks in advance.
Stephen
Re: PIX and FTP Connection Issue
are you using tcp/31 instead of tcp/21 for ftp ?
Yes, we need to have three seperate ftp servers on the one machine. So we were hoping to use ports 31/32/33.
At the moment I am just testing on 31.
Sorry should have mentioned that in the post.
fixup protocol ftp 31
if you are running 7.x code
class-map FTP_31
match port tcp eq 31
policy-map global_policy
class FTP_31
inspect ftp
service-policy global_policy global
Vikram
Thankyou for the help.
Vikram your suggestion was perfect. Problem Solved.
Thanks Again
191
