Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
PIX/ASA in failover with Dual ISP
Hi, I am wondering if anyone out there has a failover active/standby or active/active PIX (or ASA) pair which is also using 2 ISP connections with the route tracking option on.
Any comments on if it is a successful config would be appreciated.
Kelvin
1 REPLY
Bronze
Re: PIX/ASA in failover with Dual ISP
ISP failover is a feature offered by PIX/ASA version 7.2.1 or later.
This feature provides the option to configure a backup ISP route so that if the first route goes down, the second link automatically takes over to provide uninterrupted Internet connectivity.
This feature is called Tracking and it enables the PIX to continuously query and monitor a remote device/IP address via Internet Control Message Protocol (ICMP) (in this case a remote ISP's default gateway). If ICMP monitoring detects that the device is down, then a backup route takes over.
You can refer this link for configuring ASA failover with dual ISP
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
316
