Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
pix-asdm-refresh-issue
Hi Team,
im having pix 515 with os 708 & asdm 508 versions. assume i have few lines similar to the below.. I have installed the asdm for the first time and i am getting the errors as attached here...
asdm group abc
asdm group def
asdm group ghi
now i am unable to send those lines to the pix, if i send it, then again im getting into the loop of same stages..... i tried deleting those lines in pix manually and then saved id in cli. then accessed asdm, but still same problem is coming...negther im able to send those lines, nor refresh it. pls help. if i do a "sh run | in asdm" and show startup | in asdm", i can see that there are many asdm line configurations in "startup config", but not in running config.
pls help...
Hi Rajesh,
We have seen similar issues in the past in the 7.0 code. Given the age of the 7.0 code and the end-of-life status of the PIX, I would suggest upgrading to the last 7.2 and ASDM 5.2 images. This should take care of the 'asdm group' problem.
-Mike
Community Member
Thank you very much Mike...
Would you please help me to resolve the below thread issue...
https://supportforums.cisco.com/message/3503118#3503118
366
