PIX - Connection timeout configuration
I've just started dealing with PIX.
We have a couple of vpn's (cisco837) connecting to a pix firewall. Some users reported connections dropping after a certain time of in-activity and they want to know how this is configured on the firewall.
I've checked config and found:
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
vpngroup easy_vpn_remote idle-time 1800
So my question is which one controls the timeout?
Re: PIX - Connection timeout configuration
Its been a little while sinced I have used a PIX but pretty sure it is:
The 1800 represents seconds, which is 30 minutes.
Hope that helps
Thanks Ryan,
So what timeout conn controls? I mean, from what I read it says all "tcp" connections.
133
