PIX debug failover reference
Does anyone have a good reference for understanding the PIX debug fover commands? I'm currently looking for help with the "debug fover switch" where I'm seeing the error below:
fover_parse: Secondary: Switching to FAILED for reason 17.
1 ACCEPTED SOLUTION
Silver
Re: PIX debug failover reference
Here ..
Number Description
0 No error
1 normal master
2 no fail over cable
3 no power detected from other side
4 unable to talk to the other side
5 interface failed at other side
6 do not see traffic count change
7 the otherside want me take over
8 fail reported by the other side
9 LAN FO interface failed at other side
10 because state check
11 set by the ioctl cmd
Addition Reason for switch to Standby
12 bad/incompleted config
13 ifc check, mate is healhier
14 the otherside want me standby
15 in failed state, can not be Active
16 switch to failed state
Reason for switch to failed
17 MATE_ASKED
18 MATE_BETTER
19 MY_IFCFAILED
20 MY_COMMFAILED
21 FOVER_UNKNOWN
I hope this table helps. In your case, Secondary failed because Primary asked Secondary to go in Failed state. We need to look into syslogs to find out the reason why Primary asked so.
Vibhor.
1 REPLY
Silver
Here ..
Number Description
0 No error
1 normal master
17 MATE_ASKED
18 MATE_BETTER
19 MY_IFCFAILED
20 MY_COMMFAILED
21 FOVER_UNKNOWN
Vibhor.
361
