Gold
PIX, drop packets with TCP reset or ICMP
I'm assuming (perhaps wrongly) that the pix silently drops connections denied via access rules. Is there a way I can selectively drop packets on the PIX and send a TCP reset or ICMP dst unreachable reply. I'm hoping by adding a little something to the ACL entry, like "with-reset" or whatever.
Thanks.
1 REPLY
Gold
Re: PIX, drop packets with TCP reset or ICMP
well, I stand corrected. Finally got wireshark downloaded, and TCP resets are the norm. UDP I'm less concerned about anyway.
242
