Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
PIX failover question
Hi.As I don't have much experience with PIXes I'm seeking some advice concerning following failover configuration.I have 2 PIXes connected through a failover cable and after entering show failover command I get the result that my secondary PIX is in active status and my primary PIX is in standby status.
All interfaces on both primary and secondary PIX are showing as normal along with cable status.What I was wondering is if my secondary PIX that is now active goes offline will the primary PIX currently in standby take over?If not how can I make sure it does?
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: PIX failover question
This is fine. if the standby firewall fails then yes your primary firewall will become active again.
Jon
Jon
Community Member
Thanks for the fast reply Jon.I wasn't sure it would work like that considering my secondary PIX is active and I don't have much experience in that area but your answer eased my mind quite a bit.Thanks.
153
