PIX LAN FAILOVER
jeansamarani
Hi All,
I wanted just to check the impact of running 2 PIX 535 as Active/Standby with different Image 7.2.2 and 8.0.2
I am getting only this warning:
Any feedback is appreciated.
Jean
************WARNING****WARNING****WARNING********************************
Mate version 8.0(2) is not identical with ours 7.2(2)
Richard Burts
Jean
It is my understanding that to run failover both PIX must be running the same version of code. I am not sure whether this is really a "warning" or whether it is really an "error". I suggest that you get both PIX on the same version of code before you run failover.
Rick
Rick
somsh
Both Devices should be in same version.
Otherwise it will not sync.
