Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
pix nat problem
Hi Guys
ive created a policy nat on a pix 515E.
Im trying to nat a group of ip's from the outside to a pat on the inside.
I can see packets hitting a capture on the outside but nothing on an inside capture.
As an example I want 10.1.1.1 to go through from the outside to the inside on pat 172.16.10.10
config:
object-group network VMWARE-MGMT
network-object host 10.1.1.1
object-group network VMWARE-HOSTS
network-object host 172.16.5.10
object-group service VMWARE-TCP tcp
port-object eq 902
port-object eq 903
port-object eq 22
port-object eq 443
access-list 101 permit tcp object-group VMWARE-MGMT object-group VMWARE-HOSTS object-group VMWARE-TCP
access-group 101 in interface outside
access-list acl_vmware permit tcp object-group VMWARE-MGMT object-group VMWARE-HOSTS object-group VMWARE-TCP
nat (outside) 10 access-list acl_vmware
global (inside) 10 172.16.10.10
route inside 172.16.0.0 255.255.0.0 172.16.1.1
172.16.1.1 is the next hop (router). Is there something wrong with the nat?
thanks
1 ACCEPTED SOLUTION
Hi michael,what you are
Hi michael,
what you are trying to do is dynamic pat, and in this we can't specify the source port.
Please try not using port in the ACL
instead of this use ip based classification to classify the source to be patted
It is so because this is dynamic PAT that you are using so you cant specify source port on this.
so instead of above use:
access-list acl_vmware permit ip object-group VMWARE-MGMT object-group VMWARE-HOSTS
Please rate if helpful
cheers
Naveen
Hope it helps Cheers, Naveen Please Rate Helpful posts.
Hi michael,
cheers
Naveen
Thanks Naveen, I beleive that
Thanks Naveen, I beleive that fixed the issue.
I did still had problems until I created a no nat for the return traffic. I just couldnt see what was going on with the PIX.
Thanks again. much appreciated.
40
