PIX outside interface
Hello. I am trying to get the outside interface (E0) on a 515 pix to communicate to a router. I got the following ip addresses:
Router: 216.x.x.129
Pix: 216.x.x.131
Netmask of 25 bits.
I got a laptop connected to this network (via a switch), i put it's default gateway to be the router interface and set up its DNS. The laptop is able to connect to the internet. Now, i disconnected the laptop and put the same ip i used on the pix interface, in the same ip network and everything, but i can't ping the router's ip address.
What am i doing wrong or what am i missing?
Re: PIX outside interface
Is the link speed and duplex configured correctly between the pix and router?
Does a sh int eth0 show the link as being down on the pix?
Until you assign link speed, duplex, and an IP Address (even if it's just auto/auto) to the interfaces on the pix they will remain in an administratively down state.
I've also run into a situation where a freshly configured pix 501 (OS 6.3(4)) was working perfectly before deployment but failed to work at deployment time even though no configuration changes were made in the interim. I couldn't ping the DG from the pix.
I ended up erasing the configuration, clearing the ssh keys, and reconfiguring it before it would work in the new location.
Hi man, thanks for the reply. I found the problem!!! This pix was on a failover group, and by some strange reason, when disconnecting the failover link, it didn't become master. So i just went ahead and disabled failover and the pix started pinging fine.
Thanks for the help man. In fact, that's gonna help me out later when setting up the other interfaces on the pix.
alvarez_rafa,
Im new to pix firewall, I have a new pix515E. plz help me how to configure the pix so that I can ping from inside to outside interface and vice versa. also I can configure to telnet from my PC to pix via inside interface, but cannot to outside interface. plz help me.
your help would be greatly appriciated.
Peter,
petpeterpeace@hotmail.com
Probably your laptop as arp entry cached, clear the ARP on the laptop.
SK
If you are pinging from Pix it should work, try tying the ip address agian, shut and no shut the interface , clear arp cache on router and pix, this might do some magic, otherwise it difficult to understand why it not wiorking.
if you pinging behind the pix from a laptop, then there could me several issues.
Even tough High to Low works with access-list but ICMP is exception, so make sure you are allowing ICMP to come back. Also check you Global and Nat or Static.
SK
thank you for your help,
yes, I can ping to inside interface (if i connect cross cable directly to this interface, or i can also ping to the outside interface (if i connect cross cable from my pc directly to this interface), but cannot ping to inside interface (if my PC is connecting from ouside interface and vice versa)
This is the basic configuration:
nameif ethernet0 outside security0
nameif ethernet1 inside security100
interface ethernet0 100basetx
interface ethernet1 100basetx
ip address outside 209.165.201.3 255.255.255.224
ip address inside 209.165.202.129 255.255.255.0
hostname pixfirewall
arp timeout 14400
no failover
names
pager lines 24
logging buffered debugging
access-list acl_out permit icmp any any
access-group acl_out in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00
udp 0:02:00 rpc 0:10:00 h323 0:05:00
sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server community public
mtu outside 1500
mtu inside 1500
plz give me your ideas
thanks so much
Peter
202
