PIX Telnet Inside problem
hi, I have a pix 515e it's it's suddenly decided to stop allowing telnet sessions. All passwords are set and the ASDM works and the inside network is permitted telnet access, i have cleared all previous sessions, it seems as if it's actively blocking Port 23 as telnet requests are not timing out, I have check access-lists and there's nothing untoward there, is there anything else i can check? Or has anyone experinced this problem?
J mack
Bronze
Re: PIX Telnet Inside problem
Make sure you have the telnet command enabled for access to the pix:
ie:
telnet x.x.x.x y.y.y.y inside
which would allow network x.x.x.x with subnet mask y.y.y.y to telnet to the inside interface.
--Jason
Please rate this message if if helps solve some or all of your question/issue.
Yes thats definitely enabled.
Bronze
Hmmm.
Unless you're coming in from the outside interface to the inside, I'm not sure what else you're issue would be (unless you have a nat misconfiguration of some sort).
Can you you include your configuration so we can look at it?
--Jason
173
