pix515 traffic in problem
added a new vlan on one interface, connected a router and from pix, I can ping it
from inside the lan I try to ping the same remote router and fail. I also fail pinging to the vlan interface
ping to the internet is working
1 ACCEPTED SOLUTION
Re: pix515 traffic in problem
From the lan you can only ping the inside interface of the PIX.  You cannot ping the far side interface.  This is by design not allowed.
What code are you running on the PIX? both the security levels are 100 so you need this command
same-security-traffic permit inter-interface
-KS
Pls. let us know clearly what the topology is. What exactly works and what breaks.
inside n/w---PIX---new-interface--router
1. from the PIX you can ping the router
2. from the inside n/w you cannot ping the router?
What is the name of the new interface? what is the security level for that? ----> dmz ?
What is the name of the inside interface and security level for that? -----------> inside ?
If the inside is higher security level than the newly created interface then you need this
Static (inside,dmz) x.x.x.x x.x.x.x netmask 255.255.255.0
where x.x.x.x is the inside network.
-KS
lan--inside intf--pix--new intf--router1--router2
pix can ping router2
lan fail to ping new intf, router1 & router2
new-intf security-level 100 -> E2 (one of few sub-intf on this vlan)
inside intf security-level 100 ->E1
route new-intf router2_ip 255.255.255.0 router1_ip
-KS
worked like a charm. thanks!
146
